Only get @60psi in tank... help
Had the tank installed for about 6mo, no issues until this winter. I checked all the fuses and everything seems to be working. Not sure if I should replace the pressure switch with a water proof one. I current have the big grey pressure switch and it’s under the truck on the tank. Thoughts?
The pressure switch might be hindered by ice, have you tried heating it up? Ice may also be blocking hoses or valves.
Thanks, I’ll look into those things
Figured it out, The shaft on the electric motor broke at the piston. The motor would run so I thought it was pumping air into the tank.
