Removing a voice box ???
Hi all
Does anyone know how to remove the voice box from a 1976 Wife…its gone into overdrive lately and the off button seems to be broken ??? HELP !!!
Hahaha sorry, not married yet so I’ll let this one to the pro’s. Good luck!!
Space for Rent
What - no owner’s manual?
You have obviously neglected certain preventative maintenance. :wink:
You know duck tape can fix anything! :wink:
lol JK JK
K5 will overpower it
PMSL guys with your replys!!!
It was posted on another forum i visit and the thread got this reply which i though was quality
Hope This Helps
MS Girlfriend
I’m currently running the latest version of Microsoft GirlFriend and I’ve been having some problems lately. I’ve been running the same Version of MS DrinkingBuddies 1.0 forever as my primary application, and all the GirlFriend releases I’ve tried have always conflicted with it. I hear that DrinkingBuddies won’t crash if GirlFriend is run in background mode and the sound is turned off.
But I’m embarrassed to say I can’t find the switch to turn the sound off. I just run them separately, and it works okay. Girlfriend also seems to have a problem coexisting with my MS Golf program, often trying to abort Golf with some sort of timing incompatibility.
I probably should have stayed with GirlFriend 1.0, but I thought I Might see better performance from GirlFriend 2.0. After months of conflicts and other problems, I consulted a friend who has had experience with GirlFriend 2.0. He said I probably didn’t have enough cache to run GirlFriend 2.0, and eventually it would require a Token Ring to run properly. He was right - as soon as I purged my cache, it uninstalled itself.
Shortly after that, I installed GirlFriend 3.0 beta. All the bugs were supposed to be gone, but the first time I used it, it gave me a virus anyway. I had to clean out my whole system and shut down for a while.
I very cautiously upgraded to GirlFriend 4.0. This time I used a SCSI probe first and also installed a virus protection program. It worked okay for a while until I discovered that GirlFriend 1.0 was still in my system. I tried running GirlFriend 1.0 again with GirlFriend 4.0 still installed, but GirlFriend 4.0 has a feature I didn’t know about that automatically senses the presence of any other version of GirlFriend and communicates with it in some way, which results in the immediate removal of both versions.
The version I have now works pretty well, but there are still some problems. Like all versions of GirlFriend, it is written in some obscure language I can’t understand, much less reprogram. Frankly I think there is too much attention paid to the look and feel rather than the desired functionality. Also, to get the best connections with your hardware, you usually have to use gold-plated contacts. And I’ve never liked how GirlFriend is totally “object-oriented.”
A year ago, a friend of mine upgraded his version of GirlFriend to GirlFriendPlus 1.0, which is a Terminate and Stay Resident version of GirlFriend. He discovered that GirlFriendPlus 1.0 expires within a year if you don’t upgrade to Fiancee 1.0. So he did, but soon after that, he had to upgrade to Wife 1.0, which he describes as a huge resource hog. It has taken up all his space, so he can’t load anything else. One of the primary reasons he decided to go with Wife 1.0 was because it came bundled with FreeSexPlus.
Well, it turns out the resource allocation module of Wife 1.0 sometimes prohibits access to FreeSexPlus, particularly the new Plug-Ins he wanted to try. On top of that, Wife 1.0 must be running on a well warmed-up system before he can do anything. Although he did not ask for it, Wife 1.0 came with MS Mother-In-Law which has an automatic pop-up feature he can’t turn off.
I told him to try installing MS Mistress 1.0, but he said he heard if you try to run it without first uninstalling Wife 1.0, Wife 1.0 will delete MS Money files before doing the uninstall itself. Then Mistress 1.0 won’t install anyway because of insufficient resources.
Well put, I like it!
