 Register
Reply
Thread Tools Display Modes
  #1
Old 20th June 2011
ssjordan0311 ssjordan0311 is offline
Newbie
ssjordan0311 is on a distinguished road
Exclamation HELP Blowing Fuses!
I need help and bad. I have had my horn system for over 2 years and it has been going strong with no problems. All of the sudden I am blowing fuses left and right. I have checked all major connections and wire splices and installed all new connections and still I am blowing fuses. Is there anyone else out there that knows what this problem may be and how do I fix it? I miss my horn.
  #2
Old 20th June 2011
ear2ear's Avatar
ear2ear ear2ear is offline
Moderator
Default Re: HELP Blowing Fuses!
Is it your main compressor fuse? Does it blow right away?
Maybe a wire is pinched somewhere. Or worn through - for instance where a wire passes through the firewall if you didn't use a grommet.
  #3
Old 20th June 2011
Newbie
It is the main fuse near where I have the large gauge wires connected to the battery. No breaks or frays in the wiring, I have searched every inch. I am guessing i need a new pressure switch? or Maybe a bigger fuse but I have tried everything from 30 amp to 40 amp fuses. The compressor will come on and run until full and then the fuse blows or the next time I turn on the truck a fuse blows.
  #4
Old 20th June 2011
Twist's Avatar
Twist Twist is offline
Moderator
Twist is on a distinguished road
Send a message via AIM to Twist
Is your ground solid? no paint to interfere, soild connection(not loose) and preferably water free?
__________________
5 gallons....Viair 480c....Shockers....Psychoblasters....1/2" line....200psi...FTW
  #5
Old 20th June 2011
Newbie
Probably not 100% water free. I could re-check the ground. Will a faulty ground cause a fuse to blow?
  #6
Old 21st June 2011
Stinkypete's Avatar
Super Stinky!
ok....... when the fuse blows, examine the remnants of the fuse. Has it blown to smithereens or are there bobbles on the wire part of the fuse? Sometimes you can tell if it is a dead short because the fuse blows and there is not much left of it, where as a fuse that blows from overloading will have bobbles of melted metal.
The other thing to try is, when the compressor is running, feel the fuse, is it getting warm or hot? If so it could be your compressor is faulty and starting to draw more ampage than normal.
The third thing I would suggest is to disconnect the pressure switch and run a temp wire from the battery to the compressor, via a fuse and see if the compressor still blows the fuse?
__________________
8.5 GALLON AIR TANK
3 x VIAIR 400c COMPRESSORs
HORNBLASTERS MANUAL VALVE
2 x 1/2" SOLENOIDS
HORNBLASTERS 100w PA SYSTEM
  #7
Old 21st June 2011
Scaredu's Avatar
Scaredu Scaredu is offline
Godfather
Scaredu is on a distinguished road
Send a message via AIM to Scaredu Send a message via MSN to Scaredu Send a message via Yahoo to Scaredu
Default
Hell I used 80amp fuses cuz mine kept blowing..never blew again after 80amps. Lol
__________________
2006 VW Passat (Train horns coming soon...)
2004 Chevy Avalanche (SOLD)
Fully Bagged FBSS
Nathan K5LA Airchime Horn
1/2 Airlines and SMC Valves
12 Gallon Tank
Dual 480 Viair Compressor @ 200psi
Whelen WH295SLSA1 Siren/PA
Whelen SA315P Projector Series Speaker 100/200w
  #8
Old 21st June 2011
Newbie
Thanks for all the great advice. I will give all the options offered a try. Hope something works soon.
  #9
Old 21st June 2011
ear2ear's Avatar
Moderator
Quote:
Yes. It's worth taking off and sanding it clean to be sure.
  #10
Old 21st June 2011
danh@oasismfg.com's Avatar
Godfather
is it possible the check valve can cause that with some compressors?
__________________
CFM Dude
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
