Compressor will not stop running - Train Horn Forums
Old 2 Weeks Ago
gbalint gbalint is offline
gbalint is on a distinguished road
Angry Compressor will not stop running
I own a Klein train horn HK7 with a 150 PSI tank and three horns. My compressor over the last few weeks won't stop running. I replaced the pressure switch with a new one but it still doesn't seem to make a difference. I don't notice any Leakes but can't figure out what the hell the problem is. Any help would be appreciated.
Klein HK7 with a 6350RC compressor
Triple train horn w/ solenoid
150 PSI waterproof air compressor
3 gallon air tank
Pressure switch, Drain valve, Safety Valve & Outlet Air Fitting
12 ft high pressure nylon air tubing
Old 2 Weeks Ago
Default Re: Compressor will not stop running
You either have a leak, or the switch is bad/not wired up properly.
Warm soapy water will find the leak. Check your wiring to make sure it's correct, and then make sure it's doing it's job by turning on/off properly.
Old 2 Weeks Ago
ok thank you. I do not have a switch to turn it off - I have just resorted to disconnecting the power from the battery
Old 1 Week Ago
repeatman's Avatar
repeatman repeatman is offline
Shocker
repeatman is on a distinguished road
I have fallen victim to this in the past. Check your Relay
1998 Chevy Tahoe Ex Cal Fire Truck. Horns... Soon.
2010 Marin Bicycle w Torker Bicycle trailer, Grovers 1045 and 1042. 120 psi. Delco Remy Stock horns on Handlebars. TYC Alternator, York 210 (Both Pulleys turn with wheels. Centennial Car Battery for power.
2000 Honda Accord. Nathan Airchime K3HA, 7 Gallon tank, Vi-air 280-P and Vi-air 380-C, Denso 130 amp alternator from Junk yard Honda Odyssey.
Old 1 Week Ago
Oh OK. Where is the relay? I guess I can look it up on the manufacture website
Old 1 Week Ago
Here is my system. I don’t see a relay...... https://kleinn.com/product/model-hk7...rain-horn-kit/
Old 1 Week Ago
The pressure sensor generally goes in the tank so it can read the pressure.
It would be in the wiring kit if there was one.
A relay would be something you add to use a switch as a master on/off ..... anytime you use a switch, you use the switch to activate/deactivate the relay since it's made to take the abuse. A switch isn't made to handle it.
Old 1 Week Ago
ok now that I had time to test for leaks, I plugged the power back in and now the Air compressor doesn't run at all. ugh
Old 1 Week Ago
repeatman's Avatar
Shocker
so I clicked where it said "wiring Diagram" and the first thing that came up was a wiring diagram for a Relay. Its a little black box with numbers on the bottom of it "87, 30, 86, 85".
  #10
Old 5 Days Ago
First off, are you able to read the actual pressure of the system?
If it stays below the pressure switch rating, then the compressor will continue to run.
If that's the case, you either have a leak or some other reason for not building enough pressure (perhaps a bad check valve if you can't find any other leaks)
If the pressure reads above the switch rating, then check the pressure switch.
Cheap steel tanks will tend to rust and debris can sometimes cause the switch to get stuck.
In the past, I've been able to blow them out and lube them up as a quick fix.
Anyone running an ARB Twin High Performance Compressor Mickey Onboard Air Systems 1 12th March 2017 01:34 AM
Compressor won't stop running Berenice956 Train Horns 3 22nd May 2016 01:49 PM
Compressor won't stop running Jed98dirtbikes Train Horns 7 22nd August 2012 10:18 AM
Compressor won't stop FEXPLORER07 Onboard Air & Air Suspension 20 12th July 2009 02:39 AM
considering running dual train horns-one on each side of truck DumpTrucker32 Train Horns 5 25th November 2008 01:12 AM
