How often do you replace brushes? (ViAir) - Train Horn Forums
Old 22nd October 2016
Question How often do you replace brushes? (ViAir)
I've had my 450c for about 13 years now and it's been in multiple vehicles with countless cycles and zero issues
Just pulled it out of my Land Cruiser (replaced it with a 444c dual pack) and I plan on putting it in my XB with a pair of K bells
I figure now would be the best time to treat it to a set of brushes, but I'm just curious as to how often they need to be replaced
Old 6th November 2016
Default Re: How often do you replace brushes? (ViAir)
OK, I sized up where I might be installing the 450c on my beater and because it's a tight space with minimal access, I took it upon myself to pull the brush cap and see what was left in there.
I was expecting to see bare nubs, but they looked to be in excellent condition for their age and use
Cleaned up some of the dust, put a little lube on the bearing and put it back to gether.
Probably be good for another 13 years
Old 31st May 2017
djQUAN djQUAN is offline
Conductor
djQUAN is on a distinguished road
Send a message via Yahoo to djQUAN
My 7yo 400C's brushes were about the same or a little shorter than those.
2004 Toyota Rav4
Viair 400C
2gal surplus truck air brake tank
Custom Electronic pressure switch at 130psi
Three chime Semi horns for daily driving
Shocker XL for playtime
