XD3000 service interval: What needs to be done? - Page 2 - Train Horn Forums
Go Back   Train Horn Forums > Partners & Manufacturers > Oasis
 Register
Reply
Thread Tools Display Modes
  #11
Old 3rd December 2010
MarineOne's Avatar
Moderator
Default Re: XD3000 service interval: What needs to be done?
Perfect, thanks for the info
Kris
__________________
2008 Dodge Ram 3500 QCLB SRW
Nathan AirChime K3LA
Titan Fuel Tank (50 gallons)
Aero Muffler 4040XL
My ride and install
  #12
Old 17th January 2011
islandermike's Avatar
islandermike islandermike is offline
Member
islandermike is on a distinguished road
Dan, when I filled my Oasis comp I did not measure how many ounces I put in but I just filled it halfway on the sight glass is that okay? This compressor really kicks a$$, I never had a problem since I bought it. The noise is not loud at all, it is mounted on the truck bed and I can't hear it running inside the truck with the windows closed until I moved the air intake filter inside the truck. Now I can hear the hiss sound which is good for me so I know when the comp is running.
__________________
2006 Toyota Hilux
Nathan AirChime K3HA - Shocker HB4H
Two 5 gallon tanks
Oasis XD3000 Compressor
  #13
danh@oasismfg.com's Avatar
Godfather
When the oil level is near the top, it has about 10 ounces which is optimal. When it's near the bottom, it has about 8 ounces which isn't exactly the minimum but that's when oil should be added. When the oil level gets below 7 ounces there's the danger of damaging the crankshaft and rod bearings. You probably have about 9 ounces in it.
If you ever hear the pump sound like a chirping bird, that's usually due to a lack of lubrication and some damage has occurred. Even if the pump seizes there's a chance you can get it to work again. You have to unmount the compressor, put oil in the pump at least to the bottom of the sight glass, and turn the coupler that's connected to pump with channel lock plyers. If it will turn the full 360 degrees it might work again. Finish filling the pump to the top of the sight glass, hold the compressor or bolt it down to something and apply power. It will be noisier, may deliver a little less CFM, and discharge oil a little faster but it should still pressurize to 200 PSI.
__________________
CFM Dude
  #14
Scaredu's Avatar
Scaredu Scaredu is offline
Godfather
Scaredu is on a distinguished road
Send a message via AIM to Scaredu Send a message via MSN to Scaredu Send a message via Yahoo to Scaredu
hey dan! you guys ever have giveaways or contest for a compressor? lol
__________________
2006 VW Passat (Train horns coming soon...)
2004 Chevy Avalanche (SOLD)
Fully Bagged FBSS
Nathan K5LA Airchime Horn
1/2 Airlines and SMC Valves
12 Gallon Tank
Dual 480 Viair Compressor @ 200psi
Whelen WH295SLSA1 Siren/PA
Whelen SA315P Projector Series Speaker 100/200w
  #15
Godfather
Sorry, we're too small to afford giveaways. If you know of a great place where a bunch of people gather, like a fair or trade show, you could buy 2 compressors and raffle one of them so you make enough to cover the expense of the other...lol
__________________
CFM Dude
  #16
Scaredu's Avatar
Godfather
lmao!! i didnt know u guys were "small"
thought oasis was pretty big..
__________________
Fully Bagged FBSS
12 Gallon Tank
  #17
Godfather
Try really small. 1 owner, 2 employees (myself included), and 1 part time temp.
I see us getting quite bigger with some very lucrative customer leads. About 3 or 4 that started inquiring last year are evaluating or have already elvaluated our compressor and are wanting hundreds per year with increasing quantities in the following years.
I'm sure that's still small compared to Viair but it's really big for us.
__________________
CFM Dude
  #18
Scaredu's Avatar
Godfather
u guys hiring? lol
__________________
Fully Bagged FBSS
12 Gallon Tank
  #19
Old 18th January 2011
Godfather
If those customers come through, I'd be willing to bet we'll hire 1 or 2 assemblers.
It's a long way from Delaware if you're willing to move. The cost of living isn't too bad except for rent or a mortgage. Electricity will be going up thanks to the idiots in this state that passed a proposition for greener energy. Fortunately, the weather here is usually so nice that you don't need to run a heater or air conditioner 24/7.
__________________
CFM Dude
  #20
Scaredu's Avatar
Godfather
Default
if it pays 60k +benefits ill come lol
__________________
Fully Bagged FBSS
12 Gallon Tank
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
