how do I install an Oasis XD4000 on my truck - Page 2 - Train Horn Forums
Go Back   Train Horn Forums > Partners & Manufacturers > Oasis
 Register
Reply
Thread Tools Display Modes
  #11
Old 13th December 2011
danwat12345 danwat12345 is offline
Conductor
danwat12345 is on a distinguished road
Default Re: how do I install an Oasis XD4000 on my truck
I'd guess that if your wanting to use the pump a lot at once you'd need a bigger alternator or a battery that can deliver the power for a while even if the alternator can't keep up.
It's good to get an alternator that can deliver more than enough power because an alternator at "full field" (100% load) can get hot pretty quick and if it doesn't have a good cooling system, it might start to smell after a few minutes unless you rev up the engine to keep the alternator cool (like 3000+RPM).
I'd also be a bit concerned with the surge power required. I don't know if the Oasis compressors have capacitors built in but you may want to put a few big car audio capacitors in between the pump and the power source.
You might be able to run the compressor with the stuff you have already, just watch the alternator temperature and monitor the battery voltage with a cigarette lighter volt meter or something.
  #12
danh@oasismfg.com's Avatar
Godfather
A new or fully charged Odyssey PC2150 (AGM / group 31 / 100 AH) battery will run an Oasis compressor for 10 minutes before the voltage drops and the compressor slows down. It will continue to run slower and slower until it shuts down from low voltage. That's without a charge to the battery.
The Sears "Platinum" group 31 battery has the same specs, cost less, and I've heard they're made by Odyssey.
__________________
CFM Dude
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
