Go Back   Train Horn Forums > Installation Help & Advice > Miscellaneous
Old 29th January 2015
flex flex is offline
flex is on a distinguished road
Default Black Widow 1/2 manual valve
Anyone here using that valve? Would you recommend it?
Big difference in price compared to a graham white. I just need something that does the job. Not for frequent use.
uk-z28's Avatar
uk-z28 uk-z28 is offline
uk-z28 is on a distinguished road
Default Re: Black Widow 1/2 manual valve
Hi flex sorry can't help but hopefully someone will be along soon to help you out
________________________
My K5LA-TwinTanks-x4 480c Install
https://www.trainhornforums.com/showthread.php?t=6429
Wish list....
Dodge Ram SRT10 Quad Cab
Prime 990
Old Cast P5
Have a look at this.. HB was kind enough to write up a comparison a while back:
https://www.trainhornforums.com/showthread.php?t=6272
Old 30th January 2015
Thanks! I could not find that thread
Too bad they did not measure the flow for each one, I'm not buying it if it has less flow
They're a direct clone so it'll have the same flow. What it won't have is the metered output (i.e. two stage flow) as far as i know.
Old 1st February 2015
Ok im buying the clone :-)
Old 24th February 2015
Got the graham white instead of the clone. Came in today. Won't regret
