Accessory line capable of 16amp load - Train Horn Forums
Old 13th September 2019
Ramman420 Ramman420 is offline
Ramman420 is on a distinguished road
Red face Accessory line capable of 16amp load
In the hornblasters manual for the Shocker XL series, it states in the directions in Section IV...under circuit 2 about "Locate an accessory line that is capable of a 16amp load" Can anyone recommend a good source for this 16amp line? Thank you....Todd
Default Re: Accessory line capable of 16amp load
Check your fuse box, anything above a 20 amp fuse will work fine.
Or you can run an in-line fuse of 20 amp from your battery, then run key on power to the relay. Turn the key off, and it all shuts down. Key on, and you're golden.
Wink Re: Accessory line capable of 16amp load
Ill give it a whirl...TY so very much.....
Old 14th September 2019
Mntrider Mntrider is offline
Mntrider is on a distinguished road
Most vehicles, in their fuse box, have a couple extra spots that say something along the lines of “ign accessory” or just Accessory and followed it will say the amp size. I prefer the inline 40amp fuse followed by a toggle switche. This way if you got in trouble and pulled over, you can kill the compressor noise while engine is still running!
Blown horns since 2011
2017 Silverado 1500 Z71 Midnight Edition 5.3
4 Shocker XL (16 trumpets)
Goliath mount
8 gallon tank
Dual viar 444c black
Wireless remote
2019 Subaru Outback 3.6R Tour
1 Shocker XL (4 trumpets)
3 gallon tank
Single viar 444c black
Wireless remote
2011 Subaru WRX
1248awhp
8 gallon tank
Dual viar 444c
oh...very nice tyvm
if you go to a bigger volume air tank do you need to upgrade to a bigger compressor also?
I’ve ran one Viar 444C on a 5 gallon tank for the longest time. Only downside is, once you run out, you’ll have a LONG wait time till that tank is full brotha! But do what your budget lets you! That is the great part about trainhorns, you can start small and limited budget and build from there!
Goliath mount
8 gallon tank
Wireless remote
3 gallon tank
Wireless remote
2011 Subaru WRX
1248awhp
8 gallon tank
Dual viar 444c
Old 4 Weeks Ago
repeatman's Avatar
repeatman repeatman is offline
Shocker
repeatman is on a distinguished road
Your best Friend when Doing a Train horn install is Relay's.
1998 Chevy Tahoe Ex Cal Fire Truck. Horns... Soon.
2010 Marin Bicycle w Torker Bicycle trailer, Grovers 1045 and 1042. 120 psi. Delco Remy Stock horns on Handlebars. TYC Alternator, York 210 (Both Pulleys turn with wheels. Centennial Car Battery for power.
2000 Honda Accord. Nathan Airchime K3HA, 7 Gallon tank, Vi-air 280-P and Vi-air 380-C, Denso 130 amp alternator from Junk yard Honda Odyssey.
Old 1 Week Ago
yatharthmarketing yatharthmarketing is offline
yatharthmarketing is on a distinguished road
Yes i also think above 20 amp fuse will surely work fine .
3/8 line vs 1/2 line fast_five_oh Train Horns 16 28th August 2017 09:00 AM
Accessory wire in 2016 tundra? Mfear Horn Kits 3 21st September 2016 12:01 PM
Load level x air horn setup Maxhorn Onboard Air & Air Suspension 2 9th January 2015 11:36 PM
Shocking load of Shockers...... Stinkypete Miscellaneous 6 19th April 2014 06:27 PM
2010 Tacoma accessory wire Loud One Horn Kits 5 26th June 2011 02:02 AM
