Ford F250 Wiring Help - Train Horn Forums
Go Back   Train Horn Forums > Installation Help & Advice > Horn Kits
Old 8th December 2019
ARRazor ARRazor is offline
ARRazor is on a distinguished road
Default Ford F250 Wiring Help
Hey all. New to forum. Need some help with wiring. Just got a HornBlasters Conductor Special with spare tire delete. Everything is installed and now I am in need of some wiring help. I also ordered a push button switch as I dont want to use stock horn. The instructions say to "wire a fused (5A) wire from any 12v source to your switch." Need some help figuring out what 5A wire i should use to wire my switch. Any suggestions on a 2015 F250? I am not great when it comes to wiring so as much detail that can be provided would be appreciated.
Also, I someone can tell me what wire (color) I should use for wiring the pressure switch to the Ignition positive / Accessory of the truck?
Thanks in advance for help. Struggling here.
F250/350 Shocker install help needed Emanon Walkthroughs 1 5th August 2018 04:27 PM
Ford F250 upfitter switch question trick1995 Walkthroughs 11 4th October 2017 10:38 PM
Need help with Ford Upfitter switches bradinwva Your Horns & Installs 16 29th August 2012 07:04 PM
K5LA install in 08 F250 08FX4SuperDuty Your Horns & Installs 16 11th June 2009 06:13 PM
Install Options For 08 F250 KingRanchSteve Horn Kits 12 16th March 2009 01:57 PM
