Disatisfying - Train Horn Forums
Go Back   Train Horn Forums > Partners & Manufacturers > HornBlasters
 Register
Reply
Thread Tools Display Modes
  #1
Old 22nd September 2012
greygorilla greygorilla is offline
Junior Member
greygorilla is on a distinguished road
Default Disatisfying
I ordered an electric solenoid from hornblasters... It ended up malfunctioning and they made me pay out of my pocket without reimbursing for shipping it back so they could test it. They tested it as a fault... They sent me another one and this one is doing the same thing. What the solenoids are doing is hanging open at certain times... Does anyone have a solution to this?
  #2
06z71silvy's Avatar
06z71silvy 06z71silvy is offline
Super Moderator
06z71silvy is on a distinguished road
Send a message via AIM to 06z71silvy
Default Re: Disatisfying
Check your ground and voltage to the valve. Might not be the valve.
__________________
Traded my 2006 Silverado in!
I now own a 2012 Silverado LTZ w/ 6.2L!
Upcoming modifications include Nathan Airchine K3LA Train Horn. & many other mods!
  #3
Junior Member
110% sure it is the valve... Trust me i went through everything and when i sent the other one back that one was definantly faulty because he could blow through it and that would hold it open.
  #4
Junior Member
Also the solenoid that originally came with the horns I've never had a problem with... Even when i use to run them at 205 psi
  #5
Old 25th September 2012
06z71silvy's Avatar
Super Moderator
Are you installing it in the right direction. ? making sure to line up the arrows for in and out? Also which valve did you buy from HB?
__________________
  #6
Junior Member
Na man it was the right way... If it was the wrong way it would close back but possibly blow the seal out... Ends up i was right on the fault. The valve was only rated for .7 mPa so thats why. Even though they were saying 217psi. (For anyone that doesn't know 1 mPa is 145 psi and .7 mPa is 101.5 psi)
  #7
Old 26th September 2012
danh@oasismfg.com's Avatar
Godfather
I haven't seen anyone use pascals for pressure before. I thought they all used bar or psi now...lol
__________________
CFM Dude
  #8
Junior Member
Like I said they advertised it for 217psi. But this is a false advertisement because on the solenoid itself it's rated for .7mPa. It was from hornblasters, but I believe they are trying to resolve this problem
  #9
ear2ear's Avatar
ear2ear ear2ear is offline
Moderator
Is it an SMC valve? Or their other valve?
  #10
Old 30th September 2012
Junior Member
They said SMC but i don't know what that means.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
