Air Tank Rust - Train Horn Forums
Old 23rd August 2017
CN8815 CN8815 is offline
CN8815 is on a distinguished road
Default Air Tank Rust
As many in the Great Lakes Region know, it's been a very wet summer. Raining pretty much every other day, and therefore it's been very humid. I drain my tank after every use, but admittedly I forget to use the drain valve sometimes. However, whenever I'd use the drain valve, I'd typically get a light mist at best. Eventually I heard sloshing in the tank. I drained the tank from full pressure this time, and still barely any water came out, though the valve froze several times upon release. I decided to tip the tank upward as I still heard sloshing, and a large orange puddle came out.
I removed the large 1-1/2" bushings from the top of my 20 gallon tank and saw this. Some of the sludge is oil. I'm not sure how concerned I should be about this, though I routinely fill the tank to 175psi. I know now I should tip the tank upward after each use, but I'm not sure if it's already too late. Needless to say, the last thing I need is my air tank to become a second stage booster for a rocket launch, at least while I'm still using it.
-20170823_040230 by CN8815, on Flickr
Old 25th August 2017
danh@oasismfg.com's Avatar
danh@oasismfg.com danh@oasismfg.com is offline
Godfather
danh@oasismfg.com is on a distinguished road
Default Re: Air Tank Rust
I've heard some recommend putting in a small amount of anti-freeze after draining your tank but I don't know how or where they add it.
CFM Dude
World's most powerful 12/24 volt air compressors
Unrivaled performance / Exceptional service
Thanks. I dumped a few gallons of vinegar in the tank overnight and cleaned it out pretty well. There's still rust stains on the tank, but no evidence of pitting around the welds or end caps. The freezing issue I'm sure had to do with all the water in the tank. At one point I couldn't even get my horn to sound.
I guess it's a good lesson though. Unless you have a vertical air tank, or can drain the tank vertically, there's a pretty good chance the drain valve didn't remove most of the water.
Old 6th August 2018
Had my share of rusty tanks
Never had any issues with leaks, but since I run drain solenoids, they'd get plugged up every now and then.
Now I only run aluminum tanks
Old 5 Days Ago
BarrySkaph BarrySkaph is offline
BarrySkaph is on a distinguished road
Send a message via ICQ to BarrySkaph Send a message via AIM to BarrySkaph Send a message via Yahoo to BarrySkaph
Ninja tanks are, in my opinion, the best tank and regulator that you can buy.
However, if youre not looking for or cant afford the best and the greatest, most any compressed air tank will be just fine.
Old 4 Days Ago
I use an electric valve on my tank to dump it, and I cut the brass elbow a bit where it screws into the tank so it empties into the line and away from the tank. No tilting, no mess, super easy.
Tap the button a few times and all that crap gets shot out.
Old 1 Day Ago
tdriver113's Avatar
tdriver113 tdriver113 is offline
tdriver113 is on a distinguished road
Paintball air tank ? Not enough capacity for horns.
2016 Chevy Tahoe. Now where to put those Horns.........
