Go Back   Train Horn Forums > Automotive > Suspension & Air Ride
 Register
Reply
Thread Tools Display Modes
  #1
Old 14th July 2010
carramerod's Avatar
carramerod carramerod is offline
Senior Member
carramerod is on a distinguished road
Default Rear bag question
i have a gmc 1500 lifted 9.5" on 37" tires. What i want to do is put bags in the rear so at the flip of a switch it can drop to the ground and come back up to my normal lifted height. I do a lot of trailering as well so it would have to hold up to alot of weight in the rear. Is that possible to do something like this or am i dreaming??? Any help would be great,
  #2
Old 14th July 2010
LanceM@VIAIRCorp.com's Avatar
LanceM@VIAIRCorp.com LanceM@VIAIRCorp.com is offline
Pneumatic Guru
LanceM@VIAIRCorp.com is on a distinguished road
Default
There's no way in hell you're going to make it "drop it to the ground" unless you design a fully articulated rear suspension of that sort of travel, and then determine how to make an air spring or other pneumatic leveling device work in such a large stroke.
__________________
http://i34.photobucket.com/albums/d1...Web_Banner.gif
"Look, if your horns are chrome, then they're NOT train horns, capish?"
2012 Toyota Tundra Crewmax 5.7 liter, 4x4
  #3
Old 26th July 2010
carramerod's Avatar
Senior Member
Default
Thats what i figured.....So what kind of bags would i need to just have it drop in general. I would want to to drop at least 12" if not more. ps thanks for your help
  #4
Old 26th July 2010
ear2ear's Avatar
ear2ear ear2ear is offline
Moderator
Default
How tall is you lift?
Don't know much about airbags, but the axle to frame clearances would be the same as a static drop.
A stock 2wd can be lowered about 4" before having to "c-notch" the frame.
A stock 4wd can be lowered about 5" before notching...
  #5
Old 26th July 2010
carramerod's Avatar
Senior Member
Default
My truck has a 3" body lift and 6.5 Suspension lift
  #6
Old 26th July 2010
Pneumatic Guru
Default
If you add air springs (bags), you will not get any drop - since the suspension is holding the truck at its current height. You may get some lift, but its going to ride hard as a rock with any amount of air pressure in the bags. People with lifted trucks generally use bags to increase their towing capabilities.
Then there's Kelderman, whose suspensions are meant to be adjustable.
http://www.keldermanmfg.com/
__________________
  #7
Old 26th July 2010
ear2ear's Avatar
Moderator
Default
Nevermind - I reread your original post.
  #8
Old 31st August 2010
signal13's Avatar
signal13 signal13 is offline
Junior Member
signal13 is on a distinguished road
Default Re: Rear bag question
I just installed Airlift 5000 bags on my 07' Sierra 2500HD. I actually found that with no extra weight on the truck, it rides much softer and smoother with about 25 psi in each bag. When I put 60-100 psi---Hard as a rock and bounces all over the road with no extra weight. I would only need to crank them up when I attach the camper or have a load of stone in the bed.
__________________
2007 GMC Sierra 2500 HD, 6.6 L Turbo Diesel
Conductor's Special 540
Shocker S4 XL
Viar 400C
5 Gallon
Airlift 5000
  #9
Old 12th January 2011
T*****S***** T*****S***** is offline
Junior Member
T*****S***** is on a distinguished road
I have those in my 07 sierra 1500 and I love them, rides a whole lot smoother and softer. Well worth the money
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
