Go Back   Train Horn Forums > Automotive > Suspension & Air Ride
 Register
Reply
Thread Tools Display Modes
  #1
Old 22nd March 2013
daywen daywen is offline
Newbie
daywen is on a distinguished road
Default Adding airbags to shocker system
I have the shocker classic 228VX kit on my 2003 F150 Harley truck. I want to add rear bags. What do I need to integrate them into the existing system?
I want either auto leveling, or manual adjustment... Just want to see what options ther are.
  #2
Old 22nd March 2013
DBO's Avatar
DBO DBO is offline
Horn Addict
Default Re: Adding airbags to shocker system
Others with air suspension will probably chime in soon, but I reckon you'll be needing to upgrade that air system if you intend doing stuff like that. Consider a constant duty compressor for a start and opt for 5 or more gallons if you want to run the Shockers plus bags from the one system
__________________
Train Entertainment System:
The Collection:
Nathan Airchime: K5LLA, K3LA
Shocker S4 XL
  #3
Old 24th March 2013
Stinkypete's Avatar
Super Stinky!
I had bags on my set up & run them off a 2gallon tank set up & they worked fine, though like DBO said, a constant duty compressor would be help.
__________________
8.5 GALLON AIR TANK
3 x VIAIR 400c COMPRESSORs
HORNBLASTERS MANUAL VALVE
2 x 1/2" SOLENOIDS
HORNBLASTERS 100w PA SYSTEM
  #4
Old 25th March 2013
MarineOne's Avatar
Moderator
Mine are manuals.
I started with the Firestone kit, but the in cab gauge kept failing. I swapped it out with an electric valve and the AirLift Wireless AIR manifold with their remote control (see the link in the signature below) and it's been working well.
I can step out and visually level my truck, or do a remote dump and scare people
__________________
2008 Dodge Ram 3500 QCLB SRW
Nathan AirChime K3LA
Titan Fuel Tank (50 gallons)
Aero Muffler 4040XL
My ride and install
  #5
Old 26th March 2013
danh@oasismfg.com's Avatar
Godfather
I recommend a pressure regulator on a dedicated tank output for the bags. Horns can drain a tank so you might need something to keep enough pressure in the tank.
__________________
CFM Dude
  #6
Old 27th March 2013
Tlauden's Avatar
Tlauden Tlauden is offline
Senior Member
Tlauden is on a distinguished road
Default
Maybe a dual tank setup with a check valve in between? If you do it right you could use only 1 for honking but both for the air bag system. Just an idea, it would take some planning on how to hook everything up.
Posted using Tapatalk
__________________
Engineer/Conductor at Norfolk Southern
Nathan K3H
  #7
Old 27th March 2013
Angie@hornblasters Angie@hornblasters is offline
Senior Member
Angie@hornblasters is on a distinguished road
It would probably be rare that you would be using the horns AND the bags at the same time so 2 gallons would most likely be sufficient enough for each application. You would probably have to add a T fitting to give you an extra port off the tank to then run a separate line to the bags. Then integrate your switch weather it be manual or electric. We have the helper bag kits here. They are sold as a kit correlating to the specific vehicle make and model. They come with a schrader valve fitting that you would remove and plumb into your existing air system.
__________________
"Don't blow your temper, blow your horns"
HornBlasters, Inc.
39440 Pattie Road
Zephyrhills, FL 33540-3158
USA
Toll Free: 1-877-209-8179
Phone: +1 (813) 783-8058 x308
Email: Angie@hornblasters.com
AIM: hornblasters
Facebook: www.facebook.com/hornblasters
Myspace: www.myspace.com/hornblasters
Our Blog: blog.hornblasters.com
Twitter: www.twitter.com/hornblasters
Instagram: Hornblasters
  #8
Old 29th March 2013
MarineOne's Avatar
Moderator
Quote:
I plan on dropping in a regulator for the line running to the bags, but for now it's just a 1/4 inch electric valve that opens via a signal from the manifold. From there, the manifold just directs which bag gets air. If I need to air down the bag(s) the manifold controls that on it's own and the air exits the manifold.
Big props to AirLift for making this whole process a much easier solution.
__________________
Aero Muffler 4040XL
My ride and install
  #9
Old 23rd July 2015
Boomerger's Avatar
Boomerger Boomerger is offline
Junior Member
Location: Sunny So CA. (where the smog hits the pavement with a loud "clang"!)
Boomerger is on a distinguished road
A question to MarineOne, if I may. You mentioned a remote dump. Since I am fairly new at this (I at one time had just the horn system mounted on the roof of my SUV and only used them) I want to now install a horn system AND a rear leveling system on my Nissan Altima so I can better tow a utility trailer. Can you explain a "remote dump"? I might have experienced one once when a vehicle behind me did it (a loud "PSSSSH" sound) and then the truck drove off, slightly lower than before, but I never was looking in his direction to see anything escape, or see him going down, just the loud noise of air escaping. Would that have been a "dump", whether remote or not? Thanks, Dude.
__________________
Boomer Said That!
To update your download, you must first download an update!
HAWNK if yer HAWNEY!!
  #10
Old 23rd July 2015
MarineOne's Avatar
Moderator
So the loud "PSSSH" sound is the air bags dumping out into the atmosphere, and that's controlled by whatever is being used to air up/down the air bags.
Now a remote tank dump is when you put an air line and electric valve on the bottom port of the tank. This way, you hit a switch and drain the water and gunk from the tank versus climbing under your vehicle to get to the tank and spinning open a petcock. You don't get dirty from the crap that sprays out, and it makes for a good scare if you're in close quarters when the horns would hurt someone's ears more than scaring them.
__________________
Aero Muffler 4040XL
My ride and install
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
