wingless' Kahlenberg 115 and 117 Air Whistles - Page 2 - Train Horn Forums
Go Back   Train Horn Forums > Main > Train Horns
 Register
Reply
Thread Tools Display Modes
  #11
Old 8th January 2015
wingless's Avatar
wingless wingless is offline
Senior Member
wingless is on a distinguished road
Default Re: wingless' Kahlenberg 115 and 117 Air Whistles
Here are images showing my Kahlenberg 117 whistle mounted on the arch of my 2000 Searay 380 Sundancer.
The location was selected to be close to the open array pedestal because the factory makes that location a flat rectangle for mounting the radar. The rest of the arch is a curved surface and I wanted the whistle to be straight vertical.
Last edited by wingless; 11th May 2018 at 09:25 AM. Reason: Replaced PB extortion w/ Flickr
  #12
DBO's Avatar
DBO DBO is offline
Horn Addict
Hats off to you Wingless. Must admit it's been a pleasure seeing someone take such pride in their install. Very nice. Lovely boat too!.. wish I had one
__________________
Train Entertainment System:
The Collection:
Nathan Airchime: K5LLA, K3LA
Shocker S4 XL
  #13
wingless's Avatar
Senior Member
Quote:
Thanks very much for the nice words.
The boat has been very consuming of both time and money. This is just the latest project. One prior big project was me creating my new custom enclosure, where I taught myself to sew, designed the enclosure, created the patterns, then made the enclosure.
  #14
Old 9th January 2015
wingless's Avatar
Senior Member
The base of the whistle has a ½" NPT female thread and no other mounting points.
The cavity below the whistle does not have much top-to-bottom room, so I drilled a clearance hole for the ½" pipe nipple, wrapped the nipple w/ a cut tire inner tube and used a hose clamp to expand the rubber, clamping the whistle to the fiberglass.
The whistle is very secure, w/o any movement or wobble.
Last edited by wingless; 11th May 2018 at 09:26 AM. Reason: Replaced PB extortion w/ Flickr
  #15
Old 11th January 2015
Stinkypete's Avatar
Super Stinky!
Pa other great install.
__________________
8.5 GALLON AIR TANK
3 x VIAIR 400c COMPRESSORs
HORNBLASTERS MANUAL VALVE
2 x 1/2" SOLENOIDS
HORNBLASTERS 100w PA SYSTEM
  #16
Old 17th January 2015
wingless's Avatar
Senior Member
Here is an A/V clip of the completed Kahlenberg 117 air horn installation.
This was running at about 90 PSI and was making about 95dB at 1 meter.
Kahlenberg 117 Whistle Test A/V Clip
Last edited by wingless; 11th May 2018 at 09:28 AM. Reason: Replaced PB extortion w/ Flickr
  #17
Old 11th May 2018
wingless's Avatar
Senior Member
The PB extortion images and clips were all replaced w/ Flickr. This was as much fun as it appears.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
