Compressor won’t shut off all a sudden - Train Horn Forums
Go Back   Train Horn Forums > Installation Help & Advice > Onboard Air & Air Suspension
Old 2 Weeks Ago
ARRazor ARRazor is offline
ARRazor is on a distinguished road
Default Compressor won’t shut off all a sudden
Hey all. Have had my horns installed for a couple months now and everything has been working great. I head out this morning and all of a sudden my compressor won’t shut off. I have a gauge and the pressure was up to over 200 and the safety valve was letting air out. I turned the truck off, let all air out, then started truck up again. Compressor came on and filled tank to like 160 and stopped. Then immediately came back on and continued to fill. Finally had to unplug compressor. Why all of a sudden when I have had no problems this whole time. Thanks in advance for your help.
Old 2 Weeks Ago
Default Re: Compressor won’t shut off all a sudden
Sounds like your pressure sensor is shot. This is what tells the compressor to turn off/on.
Which one are you running? Call in your order and give them your screen name for the forums and they should give you a bit of a discount.
Can't get compressor to shut off 06megacab Train Horns 8 21st April 2016 03:19 PM
Compressor shut off switch(?) EffTooFiffDee09 Train Horns 42 29th January 2013 03:14 PM
Compressor wont shut off. What to do? Dobstr Onboard Air & Air Suspension 7 10th November 2011 12:56 PM
fitting a manual shut off valve? the-devil Train Horns 7 6th August 2009 06:17 PM
I can't get my compressors to shut off... paulparker Horn Kits 10 23rd July 2009 05:26 PM
