Difference between HB and GW manual valves - Train Horn Forums
Go Back   Train Horn Forums > Partners & Manufacturers > HornBlasters
 Register
Reply
Thread Tools Display Modes
  #1
Old 25th January 2013
Angie@hornblasters Angie@hornblasters is offline
Senior Member
Angie@hornblasters is on a distinguished road
Default Difference between HB and GW manual valves
Some have requested the difference between the Graham White 353 Series and the Hornblasters brand Manual Valve and why the huge difference in price.
Ready....
The Graham White is made in the U.S.A.....The Hornblasters, Inc. brand is imported over seas.
Tada!
Both valves are 1/2" NPT connections. Both are similar in dimensions and weight. The only other difference is the handle directions are opposite.
Here are some pictures.
GW on Right, HB on Left.
__________________
"Don't blow your temper, blow your horns"
HornBlasters, Inc.
39440 Pattie Road
Zephyrhills, FL 33540-3158
USA
Toll Free: 1-877-209-8179
Phone: +1 (813) 783-8058 x308
Email: Angie@hornblasters.com
AIM: hornblasters
Facebook: www.facebook.com/hornblasters
Myspace: www.myspace.com/hornblasters
Our Blog: blog.hornblasters.com
Twitter: www.twitter.com/hornblasters
Instagram: Hornblasters
  #2
DBO's Avatar
DBO DBO is offline
Horn Addict
Default Re: Difference between HB and GW manual valves
This is great info. Here's some other bits which may interest people:
The Graham White valve can be found in various guises.
The GW 353-200
The GW-200 is an old design (no longer manufactured) which used a different valve body to what is seen today in the 100 series. The casing is larger because it had both ports facing downwards. A common misconception is that there is more air flow with the 200 valve series. The valve assembly has actually remained the same through both the 200 and 100 series so there is no difference in air flow.
The GW 353-100
This is the current design for the valve, with air ports being in-line to the valve handle. You can get modulating and non-modulating variants for the 353. Metered variants are distinguishable by a groove identification on the tip of the valve stem.
  • No Groove 1/8" Metered (24 cfm @140 PSI)
  • 1 Groove 1/16" Metered (12 cfm @140 PSI)
  • 2 Grooves 3/16" Metered (30 cfm @140 PSI)
  • 3 Grooves - Non Metered
All of the valves will flow 70 cfm @140 PSI in the fully open position.
So where are the real performance differences between the clone and the GW?
- Warranty / Durability?
- Are the flow rates the same?
- Does the HB clone offer different flow or metering variants?
- Valve Parts (are they interchangeable?)
__________________
Train Entertainment System:
The Collection:
Nathan Airchime: K5LLA, K3LA
Shocker S4 XL
  #3
ear2ear's Avatar
ear2ear ear2ear is offline
Moderator
Quote:
Originally Posted by Angie@hornblasters View Post
....Both are similar in dimensions and weight. The only other difference is the handle directions are opposite.....
It looks like you could take the 4 bolts out and rotate the handle in 90 degree increments. Is that ok?
Quote:
Originally Posted by DBO View Post
...Metered variants are distinguishable by a groove identification on the tip of the valve stem...
I have a GW and don't see any grooves. Are they obvious? Does anybody have a pic?
  #4
DBO's Avatar
DBO DBO is offline
Horn Addict
Quote:
I'm pretty sure you can on the GW. Don't know about the other one.
Should be pretty obvious. Right on the top of the valve stem. See attached. My GW is a 1/8th metered, so I'm not groovie either.
__________________
The Collection:
Shocker S4 XL
  #5
Tlauden's Avatar
Tlauden Tlauden is offline
Senior Member
Tlauden is on a distinguished road
Default
Thanks for the info, ive been wondering what the differences were.
Posted using Tapatalk
__________________
Engineer/Conductor at Norfolk Southern
Nathan K3H
  #6
Old 26th January 2013
ear2ear's Avatar
Moderator
Thanks for the pic - that is pretty obvious. Mine is definitely grooveless.
  #7
Old 28th January 2013
Senior Member
Both valves come with a one year warranty.
I am in the process of researching flow rates and metering variants but I am having very little luck.
We have never tried or heard of anybody who tried to interchange the parts so this I am not sure of.
__________________
HornBlasters, Inc.
39440 Pattie Road
USA
AIM: hornblasters
  #8
Senior Member
We have taken both valves apart and it does look as though you can take the 4 bolts out, rotate the handle and still work properly.
__________________
HornBlasters, Inc.
39440 Pattie Road
USA
AIM: hornblasters
  #9
Old 31st January 2013
06z71silvy's Avatar
06z71silvy 06z71silvy is offline
Super Moderator
06z71silvy is on a distinguished road
Send a message via AIM to 06z71silvy
I will confirn you can remove the bolts and turn the handle. IO did that on my old truck when i wanted the handle pointed toward me instead..
I'd be curious to see if you can hear a difference with both handles hooked up to a k3 or k5 at same time... Ive always wondered if my clone GW was restrictive and didnt allow the k3 to sing in its full glory.
__________________
Traded my 2006 Silverado in!
I now own a 2012 Silverado LTZ w/ 6.2L!
Upcoming modifications include Nathan Airchine K3LA Train Horn. & many other mods!
  #10
Old 3rd February 2015
Helldyce Helldyce is offline
Newbie
Helldyce is on a distinguished road
Hey guys, Just been looking at the pics of these two valves and I notice quite a few differences between the HB clone valve and the GW valve and 2 of them involve flow rate.
1) Looks like the HB clone valve has a smaller diameter valve stem. GW valve looks like it has a larger diameter valve stem. That may tell you that the seat may be bigger also. You know what they say, bigger is better! lol
2) The IN port opening on the HB clone is smaller and more restrictive than the GW IN port. Look again at the picture where the ports are facing you and notice the gap at the bottom half of the port on both valves. You will also see that the port on the HB clone is machined flat against the valve housing inside the port on the left side. This tells you that air will hit that during its travel into the valve and it also tells you that the GW valve housing is cast different in a good way.
3) The handle on the HB clone valve is light in material and not as strong.
4) HB clone - No lock washers under the bolt heads.
5) HB clone - valve housing casting different.
These are just some of the differences that I noticed just from looking at a few pictures. I'm sure that the HB clone valve will work for people and they will use it without any problems and they would never notice any difference even in flow rate, but until you have both of them in hand and also do a comparison on a real horn with a flow meter, then I believe you will notice.
I'm taking a guess that the internal parts in both of these valves would not be interchangeable also.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
