K5LA install in 08 F250 - Train Horn Forums
Go Back   Train Horn Forums > Main > Your Horns & Installs
 Register
Reply
Thread Tools Display Modes
  #1
Old 11th January 2009
08FX4SuperDuty's Avatar
08FX4SuperDuty 08FX4SuperDuty is offline
Conductor
08FX4SuperDuty is on a distinguished road
Default K5LA install in 08 F250
Well, I finished my install of my K5LA in the truck box of my 08 F250. I have always had a problem with planning projects like this, so it seems like I am constantly running to Home Depot or running to Walmart for that "one last thing" that I forgot to buy. The fact that a lot of this stuff (like air fittings) can't be bought locally, made it a long process of getting everything I needed. One last trip to Walmart last night at 2:00 AM to buy an 8 gauge amp wiring kit did the trick. I know my wiring is a mess in the pictures, but I have that all fixed now. It's loud...200 psi of wonderful noise!
__________________
Got Patriotism? Buy American!
2008 Ford F250 FX4 6.4L Twin Turbo Powerstroke Diesel
Nathan K5LA (brand new OTR with restrictor removed)
Dual Viair 480C compressors
20 gallon Firestone tank
1/2" Goodyear hose
ASCO 3/8" solenoid
  #2
Conductor
Default
I will post up a video some time this week. I have to go far away from the house to make a video though. My wife hates the horn...probably because of the $1000+ that I spent on something so stupid!
__________________
1/2" Goodyear hose
ASCO 3/8" solenoid
  #3
97BLACKciVIC's Avatar
97BLACKciVIC 97BLACKciVIC is offline
Member
97BLACKciVIC is on a distinguished road
Default
Nice. I never thought of doing it that way.
my wife said the same thing and now that im selling my truck and i've gottin a car. I tld her i dont know i i want them anymore and she flipped out on me and told me that i better not sell them.
women
__________________
www.TampaRacing.com(Moderator)
  #4
CurtisL's Avatar
CurtisL CurtisL is offline
Engineer
CurtisL is on a distinguished road
Default
rich... its possible i might slap you if you dont put those in the vic
  #5
HighRollerII HighRollerII is offline
Member
HighRollerII is on a distinguished road
Send a message via AIM to HighRollerII
Default
what all is the OTR restrictor and what was used to remove it
__________________
-- 2004 Ranger -- 11" of lift -- Nathan K3H --
  #6
Old 12th January 2009
adas's Avatar
adas adas is offline
Senior Member
adas is on a distinguished road
Send a message via AIM to adas
Default
Hmm, well I suggest 2 things... first, would be use at least a 1/2" selenoid, k5's are already stuggling for air pressure using a 1/2" so upgrading would get you louder....and the other thing, mount the horns under the truck. Creative thinking, but would be oh so much practical loud underneath the truck because the sound won't be encased in the bed..
Other then that, great install!
ps: All the fittings I've used came from lowes/homedepot No need for fancy connectors
__________________
Custom Nathan K5...
bells 1,2,1,3,1
2 1/2" valves/lines going to it
Shocker S4 1/2" valve/line
Viiar 480c + 400c
13.5 gallon
Nice
  #7
Conductor
Default
It's a small restrictor that is installed inside the manifold. here is a link to the picture of what it looks like. All you have to do to remove it is stick an allen wrench up inside the opening in the manifold and unscrew it.
__________________
1/2" Goodyear hose
ASCO 3/8" solenoid
  #8
Conductor
Default
As you can see, the hole in the center is much smaller than the outside diameter of the restrictor. This is what makes the "Over The Road" K5LA legal to use on the road.
__________________
1/2" Goodyear hose
ASCO 3/8" solenoid
  #9
Conductor
Default
Many people do not realize that the only difference between the standard K5LA and the "Over The Road" K5LA is that small restrictor. I wish the people on this site would post that information up and sticky it so that people wouldn't get ripped off by sellers on eBay claiming that they are selling "real" K5LA's that are so much better than the OTR K5LA.
__________________
1/2" Goodyear hose
ASCO 3/8" solenoid
  #10
Member
Default
oh so its just a smaller port not letting in as much air..remove it and you got a normal nathan horn..makes sense..good post!
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
