HB vs Lamphus vs Wolo vs Whelen PA systems? - Train Horn Forums
Go Back   Train Horn Forums > Automotive > Automotive Accessories
Old 13th June 2015
Question HB vs Lamphus vs Wolo vs Whelen PA systems?
Has anyone here compared these four systems?
http://www.summitracing.com/parts/wl...FcSPHwodYkUAiw
http://www.amazon.com/LAMPHUS-SoundA.../dp/B00CPE694U
http://www.raneystruckparts.com/horn...FcMSHwod1kAAsA
http://www.amazon.com/Whelen-Airhorn.../dp/B009UWXMM2
I know the Whelen will be more expensive since the horn is sold separately, but I'm curious if it's worth the added cost over the others?
I like the idea of hiding the unit under the dash using and using a hidden push button for the horn, although, my main goal is to have a LOUD and CLEAR PA system (don't really need any of the other functions)
Old 14th June 2015
Stinkypete's Avatar
Stinkypete Stinkypete is offline
Super Stinky!
Stinkypete is on a distinguished road
Default Re: HB vs Lamphus vs Wolo vs Whelen PA systems?
The HornBlaster PA is currently out of stock & has been for sometime now
The Lamphus PA, if I am not mistaken, is most likely to be made by the same manufacturers as the HB one, they are very similar, apart from the Lamphus has an extra HI LO siren & a different speaker.
I might be tempted to give the one on amazon a try, I like the idea of having the unit out of site. I took my HB one completely apart and mounted all the internals under my console with all the switches repositioned on the centre console.
(However, my speaker died on mine, so I am now without a PA)
https://www.trainhornforums.com/showthread.php?t=6818
K5 AIRCHIMES ON A LITTLE NEMO VAN
8.5 GALLON AIR TANK
3 x VIAIR 400c COMPRESSORs
HORNBLASTERS MANUAL VALVE
2 x 1/2" SOLENOIDS
HORNBLASTERS 100w PA SYSTEM
100ft 2 CHANNEL REMOTE CONTROL UNIT
check out www.hornstaruk.co.uk TWO IN THE PINKY, ONE IN THE STINKY!!
Old 14th July 2015
Boomerger Boomerger is offline
Location: Sunny So CA. (where the smog hits the pavement with a loud "clang"!)
Boomerger is on a distinguished road
Snake Eater, as an old CB'r from many years back who used to bug the snot out of people with the PA system from the Cobra PA system, try this. Buy a Cobra (or any other CB with a PA switch. Don't bother with the getting an antenna, as you will not be transmitting over CB frequencies) and have a CB tech modify the PA by adding echo to it, then connect a Bullhorn loudspeaker and hide it. If it ain't loud enough, get a 12 volt stereo amplifier and just hook up one side. The bigger output you get the louder your PA will be. You might even have to get a REALLY big loudspeaker!
Boomer Said That!:cool:
To update your download, you must first download an update!
HAWNK if yer HAWNEY!!
Old 15th July 2015
danh@oasismfg.com's Avatar
danh@oasismfg.com danh@oasismfg.com is offline
Godfather
danh@oasismfg.com is on a distinguished road
I used a bullhorn speaker with the CB radio on my '68 Dodge Charger (I really miss that car) and it was loud enough without an amplifier.
CFM Dude
World's most powerful 12/24 volt air compressors
Unrivaled performance / Exceptional service
Old 24th August 2015
Train_Horny_UK's Avatar
Train_Horny_UK Train_Horny_UK is offline
Train_Horny_UK is on a distinguished road
Ooh, that sounds like quite a good idea for me to implement. Pete, I'm looking to sell my speaker (never used) because I'm gonna have a substantial upgrade, are you interested?
"Lets Get Train Horn-y"
World Record Train Horn Setup
MY SETUP:>
http://bit.ly/1TwihDu
