Shocker Valve Question - Train Horn Forums
Go Back   Train Horn Forums > Partners & Manufacturers > HornBlasters
 Register
Reply
Thread Tools Display Modes
  #1
Old 25th June 2012
repeatman's Avatar
repeatman repeatman is offline
Shocker
repeatman is on a distinguished road
Default Shocker Valve Question
Would applying less than 12 volts hurt the electric valve? Or would it damage it?
__________________
1998 Chevy Tahoe Ex Cal Fire Truck. Horns... Soon.
2010 Marin Bicycle w Torker Bicycle trailer, Grovers 1045 and 1042. 120 psi. Delco Remy Stock horns on Handlebars. TYC Alternator, York 210 (Both Pulleys turn with wheels. Centennial Car Battery for power.
2000 Honda Accord. Nathan Airchime K3HA, 7 Gallon tank, Vi-air 280-P and Vi-air 380-C, Denso 130 amp alternator from Junk yard Honda Odyssey.
  #2
Old 25th June 2012
ear2ear's Avatar
ear2ear ear2ear is offline
Moderator
Default Re: Shocker Valve Question
I don't think too low of voltage can hurt a solenoid.
It will either have enough force to move the valve or it wont.
  #3
Old 25th June 2012
repeatman's Avatar
Shocker
Cool! Cause I think I just might have invented something.
__________________
  #4
Old 25th June 2012
iNFamasStalin's Avatar
iNFamasStalin iNFamasStalin is offline
Conductor
iNFamasStalin is on a distinguished road
Quote:
does it have to do with having a switch that you can manual control the voltage to the valve so you can make it act like a manual valve??
__________________
-Vehicle: 2010 Chevy Tahoe LT w/ Octane wheels, Nittos Grapplers, 5% tint
-OBA: Dual Air Zenith OBD2's, York 210 EDC, 10 Gallons, 3/4in line, 1/2 Valve.
-Horn: Nathan K3HA
  #5
Old 25th June 2012
ear2ear's Avatar
Moderator
Not sure where you're going with this, but a solenoid valve is either open or shut...no in between.
Curious what you got cooking.
  #6
Old 25th June 2012
repeatman's Avatar
Shocker
Quote:
yes! lol. I experimented with it today but did not get much results. I was using a Delco Remy Instrument panel dimmer switch. The horns were either all the way on or off. hmm. Any Ideas?
__________________
  #7
Old 25th June 2012
repeatman's Avatar
Shocker
I was gonna try to do an In between but failed. The horns were either all on or off. oh well, Didn't hurt to try.
__________________
  #8
Old 25th June 2012
ear2ear's Avatar
Moderator
Yes, here is my idea...but I haven't tested it yet.
http://www.trainhornforums.com/showthread.php?t=5785
Can't see why it won't work.
  #9
Old 26th June 2012
Conductor
hahah lol funny i was going to try the exact same thing in a few days.
__________________
-Horn: Nathan K3HA
  #10
Old 26th June 2012
Twist's Avatar
Twist Twist is offline
Moderator
Twist is on a distinguished road
Send a message via AIM to Twist
What if you had an remotely activated-electrical restrictor, that opened or closed- So you modify the air going into the horns at say 50psi and not hear anything really to the full blow at 140 or 200 depending on horn setup....
__________________
5 gallons....Viair 480c....Shockers....Psychoblasters....1/2" line....200psi...FTW
Reply
Tags
valve question
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
