Power for my HornBlasters Shocker Classic 228VX Train Horn Kit - Train Horn Forums
Go Back   Train Horn Forums > Partners & Manufacturers > HornBlasters
 Register
Reply
Thread Tools Display Modes
  #1
Old 7th August 2012
Teqskater Teqskater is offline
Newbie
Teqskater is on a distinguished road
Default Power for my HornBlasters Shocker Classic 228VX Train Horn Kit
Hello People,
In about 2 days my kit will finaly arive in the netherlands where i live!
I have a question about this kit: HornBlasters Shocker Classic 228VX Train Horn Kit
As you know be reading the manual it needs 16A 12V. But i don't know where to get a line in my car that carries 16A!
I own a volkswagen polo coupe fox 40 KW E2. It's an old car from '93.
I know something about electricity but not so much about car electricity.
I want to get the power from the fuse box and not directly from my car battery wich is my absolute last option. But i don't know where i can get the power from the damn thing! I know that a red fuse is 16Amps and a Blue one is 25Amps. I can see them! I can find out where they are from. But i don't know how i can get power of them!
Is there someone here with knowledge about this?
Thank you in advance,
Jules.
  #2
Old 7th August 2012
ear2ear's Avatar
ear2ear ear2ear is offline
Moderator
Default Re: Power for my HornBlasters Shocker Classic 228VX Train Horn Kit
Welcome.
Sorry I got some bad news for you. You need to come off your battery. It would be too easy to blow those fuses in your fuse box.
The trigger wire can/should go to your fuse box. It draws very little current.
  #3
Old 7th August 2012
Newbie
Thank you for your answer!
I did some research and i now know how to get the power directly and safe (fused) from the battery. Thank you for your answer.
  #4
Old 9th August 2012
danh@oasismfg.com's Avatar
Godfather
Welcome to the forum. Yeah, decent compressors need direct battery power.
__________________
CFM Dude
  #5
Old 27th September 2012
repeatman's Avatar
repeatman repeatman is offline
Shocker
repeatman is on a distinguished road
Ear and Dan are correct. You will need to run directly off the battery. The only thing I have going to my fuse box is the wire that runs from the pressure switch to the two relays that close when I switch on the ignition on my truck. I also have a toggle switch that I switch off so when I am starting the truck in the morning it doesn't make the battery work too hard when cranking the starter. Once the engine is running and the alternator is working I switch the compressors on and they fill the tank up.
__________________
1998 Chevy Tahoe Ex Cal Fire Truck. Horns... Soon.
2010 Marin Bicycle w Torker Bicycle trailer, Grovers 1045 and 1042. 120 psi. Delco Remy Stock horns on Handlebars. TYC Alternator, York 210 (Both Pulleys turn with wheels. Centennial Car Battery for power.
2000 Honda Accord. Nathan Airchime K3HA, 7 Gallon tank, Vi-air 280-P and Vi-air 380-C, Denso 130 amp alternator from Junk yard Honda Odyssey.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
