Air Zenith sending unit failure - Train Horn Forums
Go Back   Train Horn Forums > Automotive > Automotive Accessories
 Register
Reply
Thread Tools Display Modes
  #1
Old 28th April 2014
MarineOne's Avatar
Moderator
Unhappy Air Zenith sending unit failure
I have the Air Zenith 220 PSI Digital Air Gauge on my truck and this will be the third time I've needed to replace the sending unit (I bought extras for my other trucks).
Is this a known issue with them? I'm reading 90 to 130 PSI lower than my manual gauge on the tank itself.
__________________
2008 Dodge Ram 3500 QCLB SRW
Nathan AirChime K3LA
Titan Fuel Tank (50 gallons)
Aero Muffler 4040XL
My ride and install
  #2
Old 28th April 2014
Stinkypete's Avatar
Super Stinky!
Default Re: Air Zenith sending unit failure
Hey M.O, daft question, are you sure it's not a grounding issue? I have one and it's really really voltage sensitive and needs a proper clean ground?
__________________
8.5 GALLON AIR TANK
3 x VIAIR 400c COMPRESSORs
HORNBLASTERS MANUAL VALVE
2 x 1/2" SOLENOIDS
HORNBLASTERS 100w PA SYSTEM
  #3
Old 28th April 2014
MarineOne's Avatar
Moderator
Yeah the ground is good. I share it with the pressure switch, and I've even used my Dremel to clean it up before I swapped it out the first time thinking it might be the problem.
Figured I'd test it again, so I dropped the digital voltmeter and then a test light on it to confirm it was still good. I painted over it to prevent corrosion with some Rustoleum after the first swap and we're still working great.
I even replaced the connectors at the sending unit, just to make sure. Still shows a maximum pressure of 58 PSI, which is about 110 off.
__________________
Aero Muffler 4040XL
My ride and install
  #4
Old 5th May 2014
Tlauden's Avatar
Tlauden Tlauden is offline
Senior Member
Tlauden is on a distinguished road
The sending unit isn't plugged up somehow is it? Just a though.... Idk if that would affect anything
__________________
Engineer/Conductor at Norfolk Southern
Nathan K3H
  #5
Old 5th May 2014
MarineOne's Avatar
Moderator
I think they don't have a good life span. I'll test the old one out this weekend if I get a chance and see what happens.
__________________
Aero Muffler 4040XL
My ride and install
  #6
Old 11th May 2014
surrealone surrealone is offline
Senior Member
surrealone is on a distinguished road
Maybe it's time to consider a setup from Dakota Digital.
http://www.dakotadigital.com/index.c...rod/prd389.htm
I've got the 0-400 PSI sending unit (since I run a 200psi air system) and it's been installed in my pneumatic manifold under the hood for a year, now. I've had not a single issue with it, to date ... but keep in mind mine's not really exposed to the elements, as it's in the engine compartment ... so heat and water from road spray is about all it has to deal with. That's intentional on my part, by the way, as I don't expect electronics to hold up for very long when exposed to road debris, road tar/solvents, brine, and other things the undersides of vehicles regularly see -- so I made sure not to put my pressure switch and sending unit in such a place.
Worth mentioning is that I went this route instead of using an Air Zenith specifically because when researching electronic gauges I read a number of reviews complaining about Air Zenith sending unit issues ... from off readings to complete failures. The Dakota solution was more expensive ... but had/has a 24-month warranty on it. So far it's proven itself to me.
Note that you can program the Dakota Digital guage with both low and high pressure thresholds -- and it'll flash the air pressure reading when below or above the low or high threshold, respectively. The guage also has dimmer support. You're out of luck if you want a colour other than blue or teal...
Also note that resolution is 1psi for the 0-150psi sending unit ... versus 2psi for the 0-400psi sending unit. I missed that tidbit when ordering, so I initially thought something was wrong when the 0-400psi unit would only display in 2psi increments.
And no, I don't work for Dakota ... I'm just a happy customer.
  #7
Old 11th May 2014
MarineOne's Avatar
Moderator
Cool, I'll check that out .... thanks!
Swapped the old sender out, same problem. I didn't have time to find my spare (my lovely wife reorganized some stuff in the garage) before heading out to a UTV demo ride on Saturday. Had a blast .... I might look into a nitrogen tank setup for this and a set of Shockers or the horns from the Katrina kit if the wife lets me get it. I've already picked up a search light for it, and I'm looking into switching it from halogen to HID.
__________________
Aero Muffler 4040XL
My ride and install
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
