Question about remote manifold K3 install..... - Train Horn Forums
Go Back   Train Horn Forums > Installation Help & Advice > Horn Kits
Old 1st August 2019
Question Question about remote manifold K3 install.....
On my Land Cruiser, I have a set of K3's with remote manifolds fed by a single 3/4" valve leading into a splitter block with all equal length lines about 1.5ft
This was pretty simple since all bells are relatively close to each other.
On my XB, it was a different story...
I had the #1 bell way out back and the #2 and #4A hidden in each front fender.
For this setup, I couldn't do equal length lines, so to avoid any delay in tone, each bell got it's own 3/8" solenoid mounted close by.
Worked great, but I feel it was overkill and the more parts used, the higher the chance for failure.
Now I'm installing a set of K3's on my minivan and was able to fit the #1 and #2 bells within the driver's side fender and the #4A bell on the passenger side.
My question is if I use a single solenoid, how long can the lines be before there's a degradation in sound or pressure delay?
I'll be using 1/2 air brake tubing split from a single 4 way manifold fed by either a 1/2" or 3/4" solenoid.
Each line will be around 3-3.5ft from the splitter block to each bell.
Will a single noid work fine for this or should I run individual noids instead?
Old 5th August 2019
Default Re: Question about remote manifold K3 install.....
You'll be fine.
I'm running half inch ID from the manual valve in the cab of my truck, back out to underneath near the fuel tank, and heard over a mile away even with the bells facing down.
Old 5th August 2019
You'll be fine.
Old 11th August 2019
I goofed and cracked my 1/2" noid while tightening the fitting, so I used a spare 3/8" noid and it just wasn't enough to feed all three remote mounted bells, so I just ordered up a 3/4" like the one I have in my Land Cruiser
K5LA manifold question soreosandmilk Train Horns 4 11th March 2017 05:46 PM
Remote install TRAIN RANGER Train Horns 24 5th December 2015 08:14 PM
K series Manifold Technical Question sqcomp Train Horns 7 3rd April 2013 03:44 PM
manifold question cjwilliams1182 Horn Kits 1 11th April 2011 02:07 AM
Ok to install the air compressor under the truck but use the remote intake assembly? cooch Train Horns 5 3rd August 2009 01:08 PM
