Go Back   Train Horn Forums > Installation Help & Advice > Onboard Air & Air Suspension
Old 1 Week Ago
harleygtp harleygtp is offline
harleygtp is on a distinguished road
Default Wiring for (2) Air Zenith OB2
My plan is to run one large gauge amp (0/1) back to a distribution block and then off to each compressor. My question is how big of an ANL fuse do I need on the 0/1 gauge wire? Each compressor pulls max draw of 35A. Should I fuse between the distribution block and relay also?
Thanks.
Old 6 Days Ago
Default Re: Wiring for (2) Air Zenith OB2
40A before the distro, 35A from distro to each compressor.
Fuses are your best friend.
Old 5 Days Ago
I figured the more fuses the better! Thanks Kris!
Old 19 Hours Ago
ear2ear's Avatar
ear2ear ear2ear is offline
ear2ear is on a distinguished road
I haven't looked up the amp draw of an OB2, but let's say they each draw 20 amps. I agree with the 35 amp fuses for each compressor, but the fuse on the 1/0 should be bigger. It needs to be big enough to handle both running compressors. So if they draw more than 40 amps together, that 40 amp fuse will blow.
Actually, fuses are meant to protect the wire in case of a short. You want the fuse to blow before the wire melts & causes a fire. The deciding factor for sizing a fuse is the rating of the wire gauge -vs- its length. There are online charts for amp ratings of wire.
In general, even if it's cheap 1/0 and 16-20 feet of run, you could probably use a 150amp. If you want to be overly cautious, you could use a 100amp. It needs to be close to the battery, so the majority of the wire is protected.
Any time you reduce wire gauge (such as a distribution block) you need another fuse that is sized for its gauge and length. If the OB2 has like 2 feet of 10 gauge, 35amp is good.
