Go Back   Train Horn Forums > Automotive > Reviews
 Register
Reply
Thread Tools Display Modes
  #1
Old 1st August 2009
djQUAN djQUAN is offline
Conductor
djQUAN is on a distinguished road
Send a message via Yahoo to djQUAN
Default Chrome 3/8" valve
being a real cheapskate, I decided to buy the chrome valve from HB as an "upgrade" to my three chime semi horn.
here's a pic of the original valve:
the original valve has an orifice measuring a whopping 3mm!!! (I measured it) so if my horns wanted more air, this is the bottleneck.
so now I bought the Chrome 3/8" valve from HB. the valve is a bit heavy and bigger than I was expecting. but luckily, it fits. and there is barely enough room.
A habit of mine is to open things when I get them. no more warranty, but for the price, it is much cheaper to buy a new one than send this back if it breaks. so I looked around inside the valve. orifice measured 5mm. the coil is not potted so it could be rewound if needed. there is a generous amount of iron and copper inside so 2amps at 10V is enough to open the valve. (the same voltage and current rating supplied to my previous valve wasn't enough to open it even without air pressure) haven't really noticed what material the base (where the fittings go in) is made of. probably cast brass since it is a bit heavy to be cast aluminum. the coil cover is steel (and there are more iron inside for concentrating the magnetic field of the solenoid) and the screws holding the cover are stainless steel.
here's a few pics of the chrome 3/8" horn installed:
as for performance, I have a gauge in the dash and observed that it takes even less time to drain my massive 2 gal tank. haven't used it that much so I can't really say for sure that it is louder. but it does seem to be louder and the tone changed a bit. pressure tested was up to 125psi and it opens easily and quickly. short honks are no problem and there is no delay from the push of the button to the sound coming out of the horns.
__________________
2004 Toyota Rav4
Viair 400C
2gal surplus truck air brake tank
Custom Electronic pressure switch at 130psi
Three chime Semi horns for daily driving
Shocker XL for playtime
  #2
Old 2nd August 2009
Sphinx's Avatar
Sphinx Sphinx is offline
Senior Member
Sphinx is on a distinguished road
Default
I got a friend here with the same setup but he was upset when i pulled on the scene and let him have " a burst of air ". So now he wants to upgrade.......lol..... I am guessing you will want to soon if u are a real noise junkie.
__________________
_______________________________________________
2009 Cadillac SRX
Nathan K3LA -Tripple Viar 480c's - 15 Gallon Tank - Digital variable 90psi - 200psi pressure selector- SMC 1/2" Solenoid - 1/2" hoses throughout
  #3
Old 2nd August 2009
Conductor
Default
Quote:
we all know I will get tired of these. but they still get the job done for now (get traffic out of my way ) still saving up for the shockers. I still have to pay other stuff besides horns you know.
__________________
2004 Toyota Rav4
Viair 400C
  #4
Old 3rd August 2009
Conductor
Default
It's definitely louder. had a few people cussing/shouting at me when I honked at a slow poke holding us back when the lights turned green. when I heard the shouting and cussing, I then gave them another long honk. then I got even more shouting.
also, my car had a dive into a flooded road at about 30Mph. it was night and was raining the whole day and I didn't see the large pool of water. when I honked all I got was a moaning sound from the horns. hehehe, a few more short blasts and it eventually cleared and worked fine again.
__________________
2004 Toyota Rav4
Viair 400C
  #5
Old 12th December 2015
Conductor
Default Re: Chrome 3/8" valve
After 6 years, the chrome valve is leaking and losing a bit of air.
So, I bought some very high quality SMC valves from HB.
Old chrome one in the horn
Old and new
Barely enough room but it fit.
__________________
2004 Toyota Rav4
Viair 400C
  #6
Old 7th January 2016
twr's Avatar
twr twr is offline
Junior Member
twr is on a distinguished road
after 6 years heck you must not live where they dump salt like here!!
__________________
2010 Dodge Cummins Daully
Nathan K3L Box mounted
5 gal Tank Box mounted
1/2 HP Compressor Box mounted
Remote fob for compressor and Horn
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
