Go Back   Train Horn Forums > Automotive > Reviews
 Register
Reply
Thread Tools Display Modes
  #1
Old 12th July 2012
SoCalMike's Avatar
SoCalMike SoCalMike is offline
Member
SoCalMike is on a distinguished road
Thumbs up HornBlasters Rocker Kit
Truck: 2005 Silverado 1500
Kit: Hornblasters Rocker - Hornblasters 1/2in Valve - Hornblasters 110/150psi pressure switch
It's almost been a year now since I've had it installed on my truck, and, for the most part, it's been ABSOLUTELY %#&@$ AMAZING!!!
...I would give the Rocker kit a 4.8/5
It's WAAAAAAAAAAAAAY louder than I thought it was going to be, even before I upgraded the air valve and the pressure switch lol. They're made VERY durable, and even after I beat the s*** out of my truck, bombing HUGE puddles and getting them completely filled with water...once the water is blasted/honked out they worked just fine, and they're STILL holding tough.
PROS:
  • it's LOOOOOUUUUUUUUDDDDDD!!!
  • Price paid to noise payoff is worth the $319
  • Comes with (ALMOST) everything you need
  • Construction / Quality / Durability
CONS:
  • The install isn't as straight forward as some people might think and the "detailed" instructions are just short of worthless. Be sure you have at least SOME background knowledge on how to wire things in a 12v system.
  • Doesn't come with a separate "honk" button for those who don't want it hooked to the stock horn.
  • Horns (over a decent period of time) become "out of tune" and start to squeak due to vibration. It's a REALLY easy fix, but it gets a little annoying. But I think this is a problem for everyone who has the shocker style plastic horns.
  • .....................and that's pretty much it.
Would I suggest buying this kit!? You're damn right I would!!
If you're tight on spending a lot of money, or if you're like me and working with minimal vehicle space, then this kit is WELL worth the money. Way better than any of the other equally priced horn kits (IMO).
(These are before the 1/2in air valve & 150psi pressure switch)
http://www.youtube.com/watch?v=nSlQn...3&feature=plcp
http://www.youtube.com/watch?v=vmzu3...8&feature=plcp
__________________
2005 Chevy Silverdo 4.8L
Hornblasters Rocker Kit 2gal Tank
  • Hornblasters 110/150PSI Pressure Switch
  • Hornblasters High Flow 1/2" air valve
  • 100watt P/A system
  #2
Old 19th July 2012
billm0066 billm0066 is offline
Member
billm0066 is on a distinguished road
Default Re: HornBlasters Rocker Kit
Are those the two shortest of the four shockers?
  #3
Old 20th July 2012
SoCalMike's Avatar
Member
Quote:
yes they are! That's why this kit is better than those 3 horn outlaw kits they sell. Well, at least in my opinion.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
