Old 19th July 2017
Tlauden's Avatar
Tlauden Tlauden is offline
Tlauden is on a distinguished road
Default Running Airline into Cab
For all you guys running manual valves, how are you getting the air hose into the vehicle? Is everyone installing bulkhead fittings in the floor, or do you simply drill a hole and run the air line through? Im working on re-installing my horns and am debating weather to do a manual valve or an electric solenoid.
Engineer/Conductor at Norfolk Southern
Nathan K3H
Old 19th July 2017
Default Re: Running Airline into Cab
What type of vehicle?
My truck has this oblong shaped holes with plugs, so I just popped one off and ran it up through there.
Old 21st July 2017
tdriver113's Avatar
tdriver113 tdriver113 is offline
tdriver113 is on a distinguished road
I ran an airline into and out of the cab floor on a 97 Ram pickup using bulkhead compression fittings. Had to drill through the floor under the seats. Good cab seal and good airline seal. Well worth the cost.
2016 Chevy Tahoe. Now where to put those Horns.........
Old 25th July 2017
Tlauden's Avatar
Thats what I did last time and wasn't happy. The way the lines ran through wasn't clean and they came out at a weird place in the cab (under rear seat). The truck I have now has the same plugs (both 3rd gen rams) and I'm wanting to stay away from that.
I was thinking of something along these lines also. Where did you find your fittings though? When I search for bulkhead fittings online I keep getting fish tank supplies LOL
Nathan K3H
Old 26th July 2017
tdriver113's Avatar
fast fittings.com . They have a good selection.
Old 30th July 2017
Tlauden's Avatar
Ill check it out, thank you
Nathan K3H
Old 31st July 2017
harleygtp harleygtp is offline
harleygtp is on a distinguished road
What size line were you using?
Old 6th August 2017
tdriver113's Avatar
I used 1/2 inch airline.
Old 11th August 2017
Mcmaster Carr has a lot of fitting also.
