#11
![]() Quote:
IMO a failure at 200 p.s.i. would be no fun. |
#12
Damn straight! Always drain your tank before doing any kind of work on your system - I learned the hard way when I had a brass check valve explode @200psi right next to my head whilst trying to crimp up a small leak. It's left me with a bit of permanent hearing damage.
Train Entertainment System: - 2010 Suzuki Grand Vitara with Twin Viair 480C's; 200psi; Norgren regulator (R73G-4AK-RMG);Twin 1/2" lines (GW line regulated @110, SMC line @200); 5 gal.tank; K3LA on custom manifolds; SMC/VA85 solenoid; Graham White 353-100 (Install | Videos | Schematic). The Collection: Leslie SuperTyfon: RS5T, RSL3L Nathan Airchime: K5LLA, K3LA Shocker S4 XL |
#13
#14
Huh?
#15
Who?
1998 Chevy Tahoe Ex Cal Fire Truck. Horns... Soon. 2010 Marin Bicycle w Torker Bicycle trailer, Grovers 1045 and 1042. 120 psi. Delco Remy Stock horns on Handlebars. TYC Alternator, York 210 (Both Pulleys turn with wheels. ![]() 2000 Honda Accord. Nathan Airchime K3HA, 7 Gallon tank, Vi-air 280-P and Vi-air 380-C, Denso 130 amp alternator from Junk yard Honda Odyssey. |
#16
Ouch!
Is this a new word game...LOL? Was the check valve rated for 200 PSI? I think brass would be rated higher.
CFM Dude World's most powerful 12/24 volt air compressors Unrivaled performance / Exceptional service ![]() |
#17
![]() Quote:
![]() https://www.trainhornforums.com/show...ht=Check+valve
#18
![]() Quote:
The printed data sheet included w/ the part lists a maximum working pressure of 250 p.s.i., a maximum temperature of 450°F and a maximum compressor speed of 400 R.P.M. The internal moving mechanism could be hurt by excessive torque. The instructions specify 10 ft-lbs of tightening torque, maximum. ![]() Last edited by wingless; 11th May 2018 at 10:31 AM. Reason: Replaced PB extortion w/ Flickr |
#19
Load Genies are extremely torque sensitive so a good rule of thumb for the male and female ports is finger snug plus 1/4 to 1/2 turn.
Thread Tools | |
Display Modes | |
