Custom compressor leader hose - Train Horn Forums
Go Back   Train Horn Forums > Installation Help & Advice > Miscellaneous
Old 17th September 2017
Default Custom compressor leader hose
Had one sitting on the shelf and decided to use it, but it's blown.
Does anyone know who makes custom leader hoses that are high pressure/high heat rated as this will be for my engine driven compressor?
Been thinking I might just see about a custom hydraulic hose since it's almost the same, then I can get high heat/pressure/oil ratings.
Thanks!
Old 20th September 2017
wingless's Avatar
wingless wingless is offline
wingless is on a distinguished road
Default Re: Custom compressor leader hose
Why not just use a standard hose, then plumb to that hose w/ the custom lengths?
The leader hose provides heat and vibration isolation, then the rest of the plumbing is fine.
