K5LA air line size. - Train Horn Forums
 Register
Reply
Thread Tools Display Modes
  #1
Old 26th November 2008
miller49g's Avatar
miller49g miller49g is offline
Junior Member
miller49g is on a distinguished road
Default K5LA air line size.
I wanted to know what size of air line should I put on my new K5LA set up? I have a Graham-White 353-101 1/16 metering valve also to use in this set up. With a 20 gallon air tank. This horn is going to be put on my 2008 3500 Dodge Ram 4X4 Cummins Diesel truck. Any info on setting it up would be appercaited.
  #2
Se7en's Avatar
Se7en Se7en is offline
-censored-
Se7en is on a distinguished road
Send a message via AIM to Se7en
Default
Most people here are useing 1/2 dot airline allthough you can use bigger
__________________
  #3
miller49g's Avatar
Junior Member
Default
Sounds good to me 1/2 dot air line.
  #4
hornblasters_tx hornblasters_tx is offline
Banned
hornblasters_tx is on a distinguished road
Send a message via AIM to hornblasters_tx Send a message via MSN to hornblasters_tx Send a message via Yahoo to hornblasters_tx
Default
hey guy, im running k5la with a 20 gallon tank as well to a 353 valve. i would recomend a 9/16inch hose line or 5/8 your choice or 1/2 if thats the route you go
  #5
Old 27th November 2008
miller49g's Avatar
Junior Member
Default
Where do you find the 5/8 to 1/2 pipe push connectors at. I would like to use the 5/8 dot air line but can't find the push connectors.
  #6
Se7en's Avatar
-censored-
Default
if you cant find them just use compression fittings
__________________
  #7
miller49g's Avatar
Junior Member
Default
I thought you could just use compression fittings on the dot air line.
  #8
Will's Avatar
Will Will is offline
Conductor
Will is on a distinguished road
Send a message via AIM to Will
Default
i use all copper 5/8 piping.and the flare fittings,works great and no leaks
  #9
08FX4SuperDuty's Avatar
08FX4SuperDuty 08FX4SuperDuty is offline
Conductor
08FX4SuperDuty is on a distinguished road
Default
Is there a problem with using the brass barbed fittings and standard goodyear rubber hose?
  #10
Se7en's Avatar
-censored-
Default
my experience with barb fittings is they have always leaked on me and compression fittings can hold more psi
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
