Please Help Air coming out horns - Train Horn Forums
 Register
Reply
Thread Tools Display Modes
  #1
Old 19th January 2014
luckyb1222 luckyb1222 is offline
Newbie
luckyb1222 is on a distinguished road
Exclamation Please Help Air coming out horns
Got the Shocker 228 conductor special on the car yesterday, everything set up correctly we are pretty sure but when the compressor is filling up the horns are blowing air. We rewired the solenoid in everyway possible and even tried grounding the wires but that didn't work. I read somebody had the same problem, a "hissing noise" and his horn diaphragms were dirty and had water on them but these are brand new horns and shouldn't have dirt. It seems like the solenoid valve is not closing or something.
  #2
Old 20th January 2014
DBO's Avatar
DBO DBO is offline
Horn Addict
Default Re: Please Help Air coming out horns
So the solenoid valve is letting through air?. Check it with both wires disconnected and make sure you have it hooked up to the airflow in the right direction (the valves are only designed to flow air one way )
__________________
Train Entertainment System:
The Collection:
Nathan Airchime: K5LLA, K3LA
Shocker S4 XL
  #3
danh@oasismfg.com's Avatar
Godfather
Welcome. Could forzen moisture be causing the solenoid to stick open?
__________________
CFM Dude
  #4
Old 25th August 2014
ramrunner ramrunner is offline
Junior Member
ramrunner is on a distinguished road
I had the same problem. Flip the solenoid around. Make sure the arrow is going the right way. I installed mine at night so I couldn't even see the arrow.
  #5
Old 28th August 2014
Stinkypete's Avatar
Super Stinky!
Solenoid has to be the right way round else your horns with start humming as you fill the tank
__________________
8.5 GALLON AIR TANK
3 x VIAIR 400c COMPRESSORs
HORNBLASTERS MANUAL VALVE
2 x 1/2" SOLENOIDS
HORNBLASTERS 100w PA SYSTEM
Reply
Tags
air, hiss, horns, shocker
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
