Electrical issues - Page 2 - Train Horn Forums
 Register
Reply
Thread Tools Display Modes
  #11
Old 1st November 2014
rccrazy30 rccrazy30 is offline
Junior Member
rccrazy30 is on a distinguished road
Default Re: Electrical issues
Quote:
Originally Posted by ear2ear View Post
Check your grounds. Make sure you have bare shiny metal. A ground with some corrosion will draw more amperage. That would explain the change. It was probably gradual.
EDIT: As mentioned above the fuse should be placed close to the power source. BUT, it has to be sized correctly. It must be rated smaller than the rating of your wire gauge & length. For example if the wire was rated for 20 amps and you had a 30 amp fuse, the wire would melt before the fuse blows. You want the fuse to blow FIRST.
my ground is a connected to the tool box via a self tapping screw nice and tight.
  #12
DBO's Avatar
DBO DBO is offline
Horn Addict
Try a better ground connection. Trays, toolboxes and other bolt on bits can be via rubber grommets etc. which can restrict a smooth path back to ground. Try running a wire straight back to the negative terminal on the battery or to a bolt point directly on the chassis.
If you can get hold of a multimeter try and measure amperage draw of the compressor when under load.
__________________
Train Entertainment System:
The Collection:
Nathan Airchime: K5LLA, K3LA
Shocker S4 XL
  #13
surrealone surrealone is offline
Senior Member
surrealone is on a distinguished road
To help prevent corrosion at grounds, you may consider coating your metal-on-metal connections with dielectric grease. It's inexpensive and VERY good defense against corrosion. If you're in an area where brine/salt/sand are common in the winter, then you may want to do this several times per year (i.e. clean off the old stuff, clean up the connection, then re-coat) as a maintenance step.
This stuff is commonly called 'bulb grease'. Don't buy the little packets of it from the auto stores, instead, get a tube of dielectric grease from Amazon.com -- you'll get a lot more of the stuff for a lot less per oz that way.
  #14
Old 4th November 2014
MarineOne's Avatar
Moderator
Honestly, if you're having issues I'd replace it all with 4 gauge welding cable.
There are plenty of brick and mortar (and online shops) that carry the stuff, and it comes in both red and black.
__________________
2008 Dodge Ram 3500 QCLB SRW
Nathan AirChime K3LA
Titan Fuel Tank (50 gallons)
Aero Muffler 4040XL
My ride and install
  #15
ear2ear's Avatar
ear2ear ear2ear is offline
Moderator
Quote:
And I'm guessing your toolbox is bolted to a painted surface. Maybe there was some bare metal where you drilled holes to mount the toolbox - maybe enough to create a good path to ground. But those are the areas that corrode over time. Just sayin' you might be better off with a connection to bare metal on the frame.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
