DBO?? Can you help identify these? - Page 2 - Train Horn Forums
 Register
Reply
Thread Tools Display Modes
  #11
Old 7th August 2015
flex flex is offline
Member
flex is on a distinguished road
Default Re: DBO?? Can you help identify these?
Quote:
Originally Posted by Stinkypete View Post
So mr.Flex, I'll work out a price & PM you (once I have tested them to make sure their working!)
Pete, you're the man ill wait for the PM
  #12
Old 7th August 2015
Stinkypete's Avatar
Super Stinky!
Omg! I just picked these up! I think have I died & gone to train heaven! The bloke I bought them off works for a company up north that scraps trains, they basically take the cab off and it gets stripped for parts, however the nose cone etc etc often gets put straight in the crusher, often complete with HORNS!!.
These two number two bells however, are apparently brand new & have just sat on the shelf & were being thrown out to make way for new shelving & storage.
When I met this guy he had a low loader lorry full of Train wheels & dolly's, I think he called them? ( All the undercarriage that has all the wheels & motors on.)
I asked him if he could get any more Horns like this & he said that he would let me know if & when he had more
Well chuffed with them!
Next I need to test them!
__________________
8.5 GALLON AIR TANK
3 x VIAIR 400c COMPRESSORs
HORNBLASTERS MANUAL VALVE
2 x 1/2" SOLENOIDS
HORNBLASTERS 100w PA SYSTEM
  #13
Old 8th August 2015
Stinkypete's Avatar
Super Stinky!
Ok, so, the story so far is this, I have since had a good look over these Horns & have found out the following about them.
They are K2 Airchimes made in British Columbia in Canada.
Here's some interesting stuff I have managed to pull off the internet about them.
The K2H with bells 1 and 2 plays D# and F#, a minor 3rd interval.
Sound clips
http://atsf.railfan.net/airhorns/k2caltrain2.mp3
http://atsf.railfan.net/airhorns/k2caltrain4.mp3
http://atsf.railfan.net/airhorns/k2caltrain1.mp3
http://atsf.railfan.net/airhorns/k2caltrain3.mp3
http://atsf.railfan.net/airhorns/index.html
Los Angeles-area commuter railroad Metrolink's Guardian-fleet cab cars have K2H horns using the #2 and 4 bells. The horns are mounted under the floor and behind the pilot to try to direct the sound down the tracks and minimize noise complaints from surrounding neighborhoods.
Some Railpower RP20BD and RP20CD genset locomotives have a K2H mounted in front of the cab in combination with a separate KS2 mounted on the rear of the cab as shown the third photo below.
Not all Railpower gensets use this arrangement; many are fitted with a single K3LAinstead.
The 1975 Nathan Airchime catalog lists the K2H as a "standard 2-tone locomotive whistle as supplied on export locomotives." Not many have apparently been supplied for use on domestic US locomotives. One early domestic use of the two-chime K-manifold was on Amtrak SDP40F's, which began to trade their Leslie SL4T horns for K5LA's when the latter became available in 1975. On the second order of SDP40F's, the SL4T horn had been split over two manifolds for lower clearance, and the replacement K5LA's were likewise split, using a standard low profile 3-chime manifold and the K2H 2-chime manifold. Photo courtesy Ed Kaspriske.
The K2H uses K-bells 1 and 2 attached to the sides of a special narrow manifold. This particular horn is fitted with optional screens over the bells to keep debris from fouling the horn.
Brand new from AirChime in Canada, a single-chime K1 horn is $1236
(U.S. dollars). As far as I know, this is more than the cost of an
entire Nathan K5LA. I've never seen a Nathan single chime horn get
anywhere near $412 on eBay either, so I think the comparison is valid.
Yes, AirChime produces a superior product in Canada, and it costs a lot
more than the Nathan horns too. Collectors know this too, check out the
final price on eBay item 4548742763. That's a lot of loons for a
single-chime horn.
I wasn't going to list my most recent findings on AIRCHIME or this subject tonight but since the K horn topic is so hot right now i will tell everyone what i recently discovered. I have contacts overseas and they buy from Airchime. The diecast quality of the brand new KS2 he sent me that had a tag from AIRCHIME Langley British Columbia was just unbeleivable. Im almost thinking that this horn was produced by someone else or in a different diecast mold. It was just perfect, with no slippy rush grinding marks or gaping seams or holes that's on all todays horns that need ground off etc, and the machine work behind the backcap is just as nice. Nothing like what we are getting here in the states today from Nathan... that's for sure. Could it be they are producing a better quality product for the over sea's market? Probably ! ... i now have the proof they are and can still make a decent quality horn.
__________________
8.5 GALLON AIR TANK
2 x 1/2" SOLENOIDS
  #14
Old 8th August 2015
Stinkypete's Avatar
Super Stinky!
Here's a couple of cheeky pics of the Horns in situ
__________________
8.5 GALLON AIR TANK
2 x 1/2" SOLENOIDS
  #15
Old 8th August 2015
Stinkypete's Avatar
Super Stinky!
Quote:
Originally Posted by DBO View Post
The endcaps are unremarkable in terms of their numbering since they are all the same. The bells should have the number cast into the side. Unfortunately I'm in Europe at the moment so I can't compare measurements from mine to the pics.
Where abouts are you in Europe mate? And what are you up to? Are you on holiday?
__________________
8.5 GALLON AIR TANK
2 x 1/2" SOLENOIDS
  #16
Old 8th August 2015
DBO's Avatar
DBO DBO is offline
Horn Addict
Yup, holidays - been touring around Germany. Started in Zurich then worked my way north. At the Baltic Sea for a few more days before starting the trek back home.
Face the channel and give us a blast
__________________
Train Entertainment System:
The Collection:
Nathan Airchime: K5LLA, K3LA
Shocker S4 XL
  #17
Old 8th August 2015
Stinkypete's Avatar
Super Stinky!
You should pop over here mate & say hello! I fitted the Shockers on the Smart car today so I could come pick you up lol (wiring them up tomorrow)
Have a good holiday my friend
__________________
8.5 GALLON AIR TANK
2 x 1/2" SOLENOIDS
  #18
Old 8th August 2015
DBO's Avatar
DBO DBO is offline
Horn Addict
Cheers Stinky. Alas, there's never enough time to tour Europe. Visiting the Kingdom will have to wait for now but I'll definitely let you know when I'm in the UK next time round.
__________________
The Collection:
Shocker S4 XL
  #19
Old 11th August 2015
Stinkypete's Avatar
Super Stinky!
Cool beans mate, enjoy your hols and stay safe mate.
Pete
__________________
8.5 GALLON AIR TANK
2 x 1/2" SOLENOIDS
  #20
Old 24th August 2015
Train_Horny_UK's Avatar
Train_Horny_UK Train_Horny_UK is offline
Senior Member
Train_Horny_UK is on a distinguished road
Mind if I briefly join in this two man chat.
I was gonna say they looked like the KS series nathan horns ('s' standing for single) but I see you've done some interesting research to find your own answers.
Pete do you know if that guy who sold you the bells only deals with nathans or did he mention if he does any other horn companies (not that I need any more than what I have currently or on order)?????
Those flat debris filters look pretty interesting too.
__________________
"Lets Get Train Horn-y"
World Record Train Horn Setup
MY SETUP:>
http://bit.ly/1TwihDu
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
