Solenoid valve seems to be stuck open above 60psi? - Train Horn Forums
Old 22nd April 2020
thewoog's Avatar
thewoog thewoog is offline
thewoog is on a distinguished road
Default Solenoid valve seems to be stuck open above 60psi?
Hello - long time no see, everyone!
Since I last posted here, I have sold the Camry and the 46115 horns, and have since bought a 2020 Kia Soul GT-Line Turbo and a Strombos Duplex horn.
I absolutely love the sound so far (basically a budget Kahlenberg D-2!), but I'm only able to sound them off at about 50psi, because if I fill the tank above 60psi, the horns start to honk themselves! Everything works normally below 60psi. I can honk the horn and it'll sound off, and stop sounding off when I let go of the button I use to activate it.
I'm using this valve
Here's a video of it happening while I was in the middle of installing everything. Anyone know what might be causing this? Do I just need to get a new valve?
Strombos Duplex with 3/8" valve and 1/2" tubing.
4 gallon air tank @ 150psi w/ Air Zenith OB2 Compressor
Old 23rd April 2020
Default Re: Solenoid valve seems to be stuck open above 60psi?
Yeah, sounds like the solenoid for the valve or the valve itself has failed.
Replace it with one made for a higher pressure and see what happens.
Old 23rd April 2020
thewoog's Avatar
Just called HB. Could be a faulty electrical switch or I could have been stupid and installed it backwards. I'll check those out later today.
Old 23rd April 2020
Yeah, the "backwards install" will likely be the culprit. Check that first. Should be an arrow on it showing flow direction.
Old 3 Weeks Ago
repeatman's Avatar
repeatman repeatman is offline
Shocker
repeatman is on a distinguished road
either your valve is on backwards or there is a tear in the Rubber Seal that seals the output. Give HB A Call if thats the case.
1998 Chevy Tahoe Ex Cal Fire Truck. Horns... Soon.
2010 Marin Bicycle w Torker Bicycle trailer, Grovers 1045 and 1042. 120 psi. Delco Remy Stock horns on Handlebars. TYC Alternator, York 210 (Both Pulleys turn with wheels. Centennial Car Battery for power.
2000 Honda Accord. Nathan Airchime K3HA, 7 Gallon tank, Vi-air 280-P and Vi-air 380-C, Denso 130 amp alternator from Junk yard Honda Odyssey.
Horns stuck open (HELP!!!!!!!) Jgreer1017 Horn Kits 9 26th December 2011 11:32 AM
Tell me what yall think. Above cab mount. Wbb_619 Train Horns 51 13th July 2011 03:59 PM
Noob from Miami (seems like a trend) motopsyko32 Introductions 19 24th February 2011 07:55 PM
air valve stuck open savagekid972 Horn Kits 4 24th August 2009 01:54 AM
Above and Beyond MeSoHonky Train Horns 3 2nd January 2009 02:48 PM
