Old 11th January 2017
n2ocharged's Avatar
n2ocharged n2ocharged is offline
Engineer
n2ocharged is on a distinguished road
Default Silverado with EDC?
Anyone with a newer Chevy Silverado (not sure how much different the engine is in older models, I have the 5.3l V8) have an Engine Driven Compressor?
I need to know how much longer the Serp belt would have to be and how difficult the installation would be...
Old 12th January 2017
Default Re: Silverado with EDC?
Call George at Extreme Outback .... when I bought mine it came with a new serpentine belt and everything to do the install.
The only issue I had was with the Dodge/Cummins combo, the install instructions called for bending the power steering lines. I just replaced them with 10,000 PSI lines from a local farm/agriculture parts place and no issues in 6 years.
Old 1st April 2017
n2ocharged's Avatar
Engineer
Kris, What's the AMP draw on the EDC you are running? I'm wiring in a new console and a new fuse block for everything but want to do it correctly. I would like to avoid installing another relay as I will already have 2 under the hood but if push comes to shove, I'll shove...
Thanks,
Nate
Old 2nd April 2017
It's run off the serpentine belt, so the only amp draw (10 amps) is for the electric clutch to turn on. Toss an inline fuse on it and it works like a champ.
When it kicks on its almost like turning on the A/C ... you feel it but the engine adjusts.
Oh, and LOADS of air!
Old 3rd April 2017
n2ocharged's Avatar
Engineer
I know, actually I contacted the company and they said it only draws 5 amps for the clutch...
Old 6th April 2017
I ran my programmer off the same power so I put a 10 amp fuse in, plus the 10's are a bit easier to find.
Pain in the oven around here when you need to buy an entire set of fuses to get some 5'ers.
