Hornblaster shockers sounding awful - Train Horn Forums
Go Back   Train Horn Forums > Partners & Manufacturers > HornBlasters
Old 13th April 2019
Mpapp99 Mpapp99 is offline
Mpapp99 is on a distinguished road
Default Hornblaster shockers sounding awful
When i installed these horns a few months ago, everything was fine and i had no issues. Now, that it’s warming up, raining, humid, my horns are sounding... not good. Some days i will blow them first thing in the morning and they sound amazing. After that, the more i blow them, the worse it sounds. They sound not loud, something it’s so embarrassing and screechy i will not even blow them. I drain my tank atleast 2 times a day, the compressor and tank are both mounted in my toolbox out of the weather, and the horns are mounted where my spare tire used to be, facing the rear of the truck and slightly angled down. I blew out my tank with compressed air and there is no water in it. Some days the horns sound amazing and others i won’t blow them at all. Idk where to start. It’s a viair 2 gallon tank and compressor setup. Just put a brand new 110/145 pressure switch in also and it’s srill doing it. Is it possible for a piece of trash to be getting hung up somewhere? Or is it the volume in the air? Or humidity? Thanks for ANY help as this is frustrating!
Old 14th April 2019
Default Re: Hornblaster shockers sounding awful
It's probably humidity.
Call HB and ask them if there is something you can use to help get rid of the water buildup.
3rd set of shockers - Already sounding off JMcGarva HornBlasters 7 5th January 2015 05:55 PM
horns sounding bad on first blow boondocked Your Horns & Installs 5 28th July 2013 05:30 PM
Unique sounding shockers repeatman Your Horns & Installs 0 11th May 2013 07:51 PM
Shocker sounding sick boondocked Horn Kits 5 7th August 2012 07:06 PM
leslie's quit sounding right xdeerex Horn Kits 15 10th May 2012 12:59 AM
