Properly ground in in truck bed? - Train Horn Forums
Go Back   Train Horn Forums > Installation Help & Advice > Onboard Air & Air Suspension
 Register
Reply
Thread Tools Display Modes
  #1
Old 15th August 2018
Dannysloco Dannysloco is offline
Junior Member
Dannysloco is on a distinguished road
Default Properly ground in in truck bed?
OK so I’m 90% done with my horn re-installation but I am having a complete brain fart.
Don’t know where or how to run the grounds from the pressure switch and the compressor.
A- Should I get a thick gauge wire to run the ground properly?
B- where in the truck bed can I ground, if at all? If not, I got to run wires out to the frame?
I haven’t had time to ask Dad, the electrical engineer.....
  #2
Old 16th August 2018
MarineOne's Avatar
Moderator
Default Re: Properly ground in in truck bed?
Compressor grounds to the frame, and use 2 gauge or bigger.
Pressure switch can ground off the compressor.
__________________
2008 Dodge Ram 3500 QCLB SRW
Nathan AirChime K3LA
Titan Fuel Tank (50 gallons)
Aero Muffler 4040XL
My ride and install
  #3
Junior Member
Thank you my friend. Hoping to grab at Home Dopey (Home Depot) on the way home tomorrow.
im 90% done. Been looking at the pics of installs on other Dodges. one other new question...I see that HB recommends the compressor be higher than the air tank but I see examples where its not. Further, I dont see how folks are installing their compressors underneath the trucks and not getting wet if in snow and puddles. What gives?
I tend to get wrapped up in “get’erdone”-itis and dont want to rush this job. Want to do it right
  #4
Old 17th August 2018
Junior Member
Success.. now just have to mount the manual valve
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
