Conductor Special..upgrade
No problem! Glad I could help!
New pressure switch and 1/2" High Flow Valve will be here tuesday…Time to gather up some 'hoe’s…pun intended…:cool:
Got it all back in!!! BUT I tested them out and it sounds as if they aren’t going off at the same time. All the hoses are the same length.
Problem 1: Since I’m using a “log” style manifold should I have to cut the hoses towards the end of the manifold to make up for the distance traveled from the inlet port??
Problem 2: Also during my testing, i have my horns wired to my stock horn wiring harness and for some reason it just stopped working??? I checked the relay in the fuse box under the hood and it is fine. I plugged in my stock horns and disconnected the shockers and still no noise from the stock horns. I then checked the new 1/2" switch by touching one of the wires to the positve battery terminal and the horns went off no problem.
SO, it seems as if my stock wiring harness has a glitch some where and I haven’t got a clue as to why…
Any help on the two problems above would be greatly appreciated!!!
I’ll toss up some pics of my setup tomorrow.
Anybody???
