Horns squeak every time i use them
Ermmmm simply send them back to HB headquarters…They have a life time guarantee folks!!!:smiley:
The lifetime guarantee doesn’t cover this. What i did to fix the problem is just use the tuning screws. Also, i hooked up the horns to a different compressor with a regulator and lowered the maximum psi to where the horns didn’t squeak but sounded great so, I’m now ordering a regulator for my in-car compressor to solve any future problem, and from my ears, I can’t hear any difference in loudness within 20 psi. Hope this helps
Ok here’s a twist I have the same issues at the lower pressures! I run 200 off and 150 on and it seems as I get to the lower side it squeals. Then shortly after comp on and fills up and good till the bottom of the pressure switch limits ! I have the wolo chief horn and viair 300. Any suggestions, comments? Thanks !
