06 Dodge Ram Horn Diagram
Im looking for a wiring diagram for the horn setup on the 06 dodge, i want to set up my truck so the train horns are activated by the stock steering wheel, also plan on putting a 3 way switch so i can use bolt standard horns and train horns.
so has anyone done this and if so can you give me some advice on how to find the correct horn wires ect. also if someone has the wiring diagram that would be great.
thanks
I have my semi horn wired into my stock horn button on my 06 Megacab. I just tapped into one of the wires down at the horns so I didn’t have to mess with any wiring under the dash. Theres two horns, figure out which wire is the hot one when you push the horn button and that will be the one to tap into. I didn’t cut the wire, I peeled some cover back and soldered another peice to it long enough to reach where I needed to go. Its alot easier to reach if you pull out the headlight assembly. Mark
