Im really looking into getting a hornblaster kit but im not sure which one to go with. I want something thats going to be a clean install and everything must mount under the truck because i have a custom stereo system in the back any suggestions im not looking anything major but i do want a good scare system jst for ***** and giggles PLEASE HELP ME OUT~!!
Shocker S4 horns sound the best for the money. after that its if you want 150 psi or 200 psi and how big of a tank you can fit/want. I have the 150psi shockers with a 2 gallon tank and am fine. although the Xb doesnt have hardly any trunk room if i remember correctly. and with you having a system may be difficult. but with a will there is a way haha. do you have any pics of your truck, or what you are working with?
you can fit a k5 or a k3 underneath a scion. Fu#k a kit. peice one together yourself get some k3s on ebay. compressors, hose, fittings, and valves get from hornblasters cause they have good prices dual compressor packs. Get you a tank from AIR HORNS OF TEXAS Jason (who sold me my stuf) has more to choose from and has them in aluminum which i would suggest. Check this out too http://www.youtube.com/watch?v=9Vetw-fZpYc&feature=channel_page
From the looks of it theres enough room for about whtever the hell you want
are the S4 pretty loud ??? like a locomotive horn because i have a jack donkey that has a lil 3 horn kit that came from a autoparts store thats really starting to tick me off and it’s time for pay back
yes except there is no way he can fit a 5+ gallon tank in his scion with a system too. and pretty much anything below 5gallons for a K3 or K5 is worthless imo
yea the shockers are pretty loud… honestly its not the horn that will be the problem, its the tank. you may need to loose a sub and just rock with the 1 and a tank on the other side. idk
he would need a new box. a lot smaller… the trunk is taller than it is wide. the Y axis is longer than the z if you can understand that. unless you went to a sealed enclosure. The type Rs have a smaller sealed spec rating than ported… OR you could make a small box with a giant port
i would really likew that much sound but damn im trying to get a CHEAP thrill 450 for horns 200 for comp after lines and tank i would have a grand it it quick
Do the shockers then, I rock them. plenty loud imo. they will kick your friends horns donkey, unless he has a K3. plus they dont need as large of a tank, as well as then being a lot cheaper
I only have 960 in mine and noone even sells a kit with as much air or compressor or manual valve as what ive got. and bro if I wanted to sell mine as a kit I could put it on ebay right next to a k3 kit with 5 gal. tank 1 compressor for 1500 and its gone used or not.
