1/2" compression fittings
Is it possible to remove the line from these once it’s pushed in (these are all brass, no plastic)? I’m all set up, but some time in May I’m moving the tank, and I’ll need to put in a longer section of line, if I have to get new fittings I want to have them ready.
It takes a bit of a pull, but yes, the line will come off. I’ve done it on mine. They seal up fine when you put the end back on again too. Just get it pushed back on nice and straight…
Great, i’ll just throw them in the vise and give ‘em a good pullin’. Thanks
