my k3a has been making funny sounds for awhile now, and tonite I finally narrowed it down - the #1 bell makes a shrill, high-pitch noise for awhile and doesn’t settle to the correct note until the tank is all the way down to 60 psi. This is with BRAND NEW diaphragms. It’s possible that the base leaks since I have custom mounts, but I highly doubt it and even so, it should just be quieter than the rest.
What can be done about this? Time to send it somewhere for remachining? If so, where?
I agree with the above suggestion. Take the diaphragms out (even try turning them around) and re-assemble it. When I bought my K3 (brand spanking from the factory) it came with one bell which wasn’t properly seated. Took it apart and put her back together and she came good.
air system looks good, so it should be getting all the air it needs ( i run 3/4" OD line to a manifold and 1/2" OD to each horn). Hoses and fittings seem to be in good shape.
I asked over at the horn and whistle board so hopefully they have some good insights. I did not replace the cushion ring however mine appear to be in good shape.
