I have two sets of Outlaw horns under my truck fed by two Viair 444c pumps into a 6 gallon tank.
Both ground wires for the horns are together and grounded good, both air valves are wired to one toggle switch.
Problem is that when I’m at 200psi only one set goes off until air pressure drops to about 140, then both will go off.
What would make the second set only go off at lower pressure? What can I do to fix it?
I didn’t know HB had a regulator. I bought a 1/4" Viair regulator for running air tools, but I bought a 1/2" high flow regulator for the horns.
Since Mr. earthdog has 2 horns, a high flow regulator would be a good idea.
Since Mr. Stinky has a K5, a high flow regulator would be an excellent idea!
That is the Viair that I have. I put a male QD on the inlet & female QD on the outlet. I just hook it to an air hose when using tools or filling tires.
