Finally looks like I’ll have a working horn mount for use with the spare tire crossmember. -And its a 100% bolt-on.
I have one coming, as well as another for Matt’s work truck…
Does anyone else want one? If so, please PM me so we can work out the details. There will only be one build run, so if you need one - get it now or forever hold your peace.
FYI - I know that the model years are specific to my truck and Matt’s truck. Toyota may have used the same hole pattern in newer Tundras, but I don’t know for sure.
Use the template in my photo area here to check to see if the holes are the same for your application.
Then again, it could be used on any flat plate that is horizontal… so this would make it work for nearly any application.
Let me know!
Thanks!
