Don’t hate:D. I’m going to find one tommorow. I could have used just a 1/4" valve for the low side, but I got a good deal on the two 1/2" valves. The ball valve gives me all the adjustablity I need from full flow to no flow. I might just do two check valves just to isolate both lines.
Found one for $12. It works just as good as shuting the ball valve, but has bleed off on the low side so it sounds kinda like a manual valve and the high side stays nice and crisp.
Got started on the York compressor today. I made a template out of plywood. I’m gonna have to reroute the upper radiator hose. It looks like I’ll be using a Gates belt part# K081377. Its 138 1/4" long. I don’t have it routed in these pics, but basically it will come off the idler puller above the fan pulley to a idler pulley right before the York clutch pulley then over the York to the power steering pulley.
Got the bracket done. The fill times are pretty impressive.
I use a piece of 1/2" plate and a piece that I had on the 6.0 motor for the dual alternators for the idler pulley. Basically it’s a piece of pipe with a 1/2" piece welded to it, drilled and tapped. The idler pulley I used is one off a big rig tensioner. It has dual bearings and is a solid piece of metal, not that stamped crap that you get on regular cars. The belt I listed worked perfect. Of course I have some pics and vids.
I put a piece of flat bar to hold the upper radiator hose away untill I figure out what to do with it.
So this is what I found at O’Reillys. I don’t know what it goes to besides Chevy/Chrysler. I used this and a piece of the stock Dodge upper hose. I join them with a pvc coupler till tomorrow when I can get metal barb.
Wow… top work. Bit of effort, but I’m sure the results are worth it.
With that pipe making a high point above the radiator and pump, just make sure you don’t get any air trapped in your coolant system otherwise you could run into issues later on.
Yeah the big electric pump went out and I was never impressed with it.
I don’t think that I may have a problem with it being this p.p.e dual fuel kit is even higher than the hose I’m using and they don’t seem to have problems.
Got a metal barb. The hose is 1 3/4" and all they make are 1 1/2" and 2" barb. So my local hose shop took a 2" and crimped it down to 1 3/4" and gave me two nice t bolt clamps to go with it.
I have a auto drain oil mist separator, so I haven’t hooked a tube and bottle to it yet. I do get some oil drops coming from the crankcase vent if I use it a lot. I think a little extension would stop it.
Stiffened it up a little more with some 3/8x1" flat bar and added a hole so I can drain the unit. Kinda forgot about that because I thought I would have to add oil all the time, but it seems not to past much oil.
On the bolt at the bottom instead of just drilling a hole and putting a bolt and nut I decided to tap the flat bar with a 3/8" tap. Getting to the nut would have been a pain in the @#$.
