My first install…
I had a few goals in mind while doing the install.
Modify the car as little as possible.
Keep trunk space.
Mount all horns in the same direction.
Keep compressor noise to a minimum.
Have an air gauge up front.
Keep it stealth!
It took me 3 days, 8 hours a day and then some to finally finish.
The car:
The horns:
My main goal here was to have them pointing in the same direction. Fitting all 4 horns into the space I had was tedious. I didnt want any horns to be visible below the car, so I had to make sure the longest horn was mounted as high as it could go without affecting the hood closing properly. So I made some L-brackets to mount the 2 longest horns. The other 2 horns are secured by giant zip ties. The air valve is secured to a frame piece with bolts and lock-nuts. The best part is, I didnt even have to take the bumper off to install them!
Underside view:
Here is a view from under the car. All horns are out of view.
The air tank:
The air tank was another issue…I wanted to mount it where it would take up the LEAST trunk space. It took me a while to find the right spot where the mounting bolts would go directly through the trunk and not through a support beam!
Another shot with my TC Sounds LMS Ultra 15:
The compressor:
This gave me the most issues. I didnt want to hear/feel compressor noise. So mounting under the trunk was the only option. I had to order a longer leader hose to reach the air tank. I also had to buy the Viair bracket. I acquired some vibration isolators (made for aircraft engines) to mount the compressor. After this, I can barely tell its on!
The air gauge:
I took extra care when installing the air gauge. I chose an Autometer gauge for reliability. I then wired in a switch that controls the gauge lighting as well as the compressor.
Overall Im happy with how it turned out. I have the air valve wired to the stock horn for now. Running the 1/2in air line from the trunk to the front was a PITA, same for the air gauge. Nothing about this install was easy, but in the end, all my goals were met!
