I have a 2004 Big Bear 4x4 that I am looking to sell so I can buy a newer bike.
This atv will start up without a problem and go through just about anything you can throw at it. It comes with a 2 inch lift kit, ITP SS112 rims, 25inch Highlifter Outlaw tires (less that 100 miles on them), and bike is snorkeled.
The bike is in full time 4x4 mode but if you know electronics if you can fix the wiring to go in between 2x4 and 4x4. The front differential is welded so that while in 4x4 all four wheels are locked and pulling together. I removed the rear brakes the front brakes currently do not work, but are there if you want to fix them.
The bike smokes a little and I have been told that it is the valve seals and it would cost about $300 to fix. If you don’t mind the little bit smoke, the bike runs just fine
Also, when turning corners the CV joint clicks so it probably needs to be replaced. Blue book for this bike is $2,640. More pictures are available
I would like $1,900, I am not longer in Florida and I am now in Bloomington, IN
