2010 Chevy Silverado Crew Cab 4x4
Added the 1 gallon ViAir tank on the driver’s side in front of the fuse/relay box. It[FONT=Courier New] fit perfect. Used existing holes in the tank bracket and tray.[/FONT]
[/FONT]
[FONT=Courier New]Mounted the ViAir 275C compressor on the diver’s side grille / headlight support bracket. [/FONT][FONT=Courier New][FONT=Courier New]Pressure switch is located under the compressor. [/FONT][/FONT]Was able to use 3 of the 4 required bolts. Had to drill two holes. When the compressor kicks on, you can hear and feel it… But nothing too bad. Splash guard covering compressor. (does not touch)
Horns were mounted vertically on the grille. Near the compressor. Had to drill 2 holes in grille to mount horns.
[FONT=Courier New]Horns seen from the front. Behind the grille. Once it is all back together. The tank is the only real visible item under the hood.[/FONT]
Drilled hole in firewall to run lines and wires to switches and gauge in the cab. This is the starter hole near the brake booster. (the compressor intake is also in the cab) [/FONT]SPDT switch to be able to switch between OEM horn or air horn. Used tan wire (-)(the correct 1 of the 3 in the same area under dash near steering column). OEM horns are 12v(+) and the air horns are wired 12v(+). Each ran to outer prongs of the switch. The center prong is the ground to the OEM horn button. OEM horn is a negative trigger.
<!–[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:“Table Normal”; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:“Times New Roman”;} </style> <![endif]–>
