2010 Ford Expedition - Shocker S6 544K Train Horn Kit
2010 Ford Expedition featuring Arturo R. running the Shocker S6 544K Train Horn Kit turned this full-size SUV into a true attention-grabbing setup built for both show and sound.
Arturo R. installed the Shocker S6 544K Train Horn Kit with the white horns neatly mounted in the front grille area, creating a clean, integrated look that matches the truck’s all-white exterior. The grille-mounted setup keeps everything tight up front while still allowing the massive sound output the Shocker S6 544K Train Horn Kit is known for. The color-matched theme gives the Expedition a seamless custom build vibe while still keeping things functional and loud when it counts.
A clean install, aggressive sound, and a sharp visual match make this Expedition stand out whether it’s rolling into a show or hitting the road.
#TrainHorn #FordExpedition #ShockerS6 #HornBlasters #TruckBuilds
#CustomTrucks #AirHorn #GrilleMount #SUVBuild #CarAudioStyle
https://hornblasters.com/products/hornblasters-shocker-s6-544-nightmare-edition-train-horn-kit
